Hey Guys/Girls,
The R32 got defected on the weekend along with my mates Ceffy (MYCEF3)
Just doing a shout out to anyone that has stock R32 parts that i can either borrow or purchase from them for regency. The only thing i got defected for was being too low and having bald tires but i need other things as they are sending me to regency for the complete overhaul. Most people probably know Carl's old car pretty well but for those who don't its got a screamer, high mount turbo, coil overs, very wide rims and a few other things that will need changing before regency.
If anyone can lend to me or sell to me some parts for my trip to regency that would be greatly appreciated. PM me for info. :devil:
https://www.sau.com.au/forums/topic/281723-defected-4-door-r32/
Hey Guys/Girls,
sux mate, but looks like you already posted help in the borrow thread so no need to flog it again here ?
sounds like your going to have to replace a heap of stuff, good luck ?
damn sounds bad,i nearlly got defected on saturday night but defect station was full of cars so they let me go, they made the station on saturday night at around 9 and it was infront of the cop shop on Hindley. :)
Edited by kb-r33
I saw like 4 33's go past that defect station..they were actually pulling over death traps and not imports.....not one import got pulled over as far as i know.....do u have clear tail lights????
yeah thats kien with the Clear taill lights lol.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
