Hey guys,
After installing my new front mount, the front bar requires some fairly decent modification, which
i expected. However, i was wondering what the best tool would be for the job? I was thinking an
angle grinder with a really fine cutting blade, but just thought before i do that id see what everyone
else uses...
Cheers
https://www.sau.com.au/forums/topic/281728-cutting-front-bar/
i don't know about anyone else who has used an angle grinder, or if the stagea front bars are made of the same material as standard 180sx front bars, but the plastic melted with the heat from the cutting disk and made a stringy fairy floss like mess :devil:
kinda cool though
  zei20l said:
a fine bladed hacksaw! or an airsaw if you have one, will make the job easier. but you migth have problems making round edges with it......
Was thinking a fine bladed hacksaw would be the best bet... but those sharp edges :D
kinda cool though
Problem solved!! ;)
Edited by iamhe77
the only fmic install i've done was in an s13 silvia. i cut the reo with an angle grinder and the plastic bumper with a dremel.
kinda cool though
watch out for this ^^^ lol. when i took to mine with the dremel, i had to set up a fan to blow the smoke away. it's toxic, smells like shit and burns your eyes. plus you get the fairy floss effect all over your dremel :D
Just do it with the angle grinder, it cuts through it like a hot knife through butter and if you careful you can get it pretty neat. You may wish to give the edges a bit of a hand sand once your done though. Also you might want to tape up the painted areas your not cutting for a bit of protection just in case anything happens. Tape is heaps cheaper than a new paint job :P
I've always just used a hacksaw blade and shaved off the fuzzy bits at the end with a scraper blade or stanley knife blade.
Hacksaw blade allows you to take your time, but you still need a steady hand.
Definitely tape the edge of your cut though, straight edge gives a nice guide and you won't mark surrounding paint accidentally.
Good luck!
  GoldZilla said:
Hahahahaha, I wonder if that spaghetti string-like mess trailing in the breeze would add to the illusion of speed when Alex is driving around. :)
HEY! There is no illusion of speed required thank you very much!
  RED513 said:
Go easy on that Days front bar, I went too far!!!
Yeah im basically gonna lose the whole number plate thingo in the middle,
as well as the two vertical parts that come down to each side.
I think im going to go the thin cutting blade on the grinder, with the really
thin ones they go through pretty quickly....thanks for everyones ideas :P
thin ones they go through pretty quickly....thanks for everyones ideas :)
:) the wife's stag has the dayz front bar and i think we'll end up doing the same :( it's probably the only kit i've seen on a car that i've liked :(
  RED513 said:
Single sided razor blade!!! clean, no mess & easy, its only plastic!
+ 1 for the razor blade/ stanley knife. did it on s1 front bar and it was easy, the plastic is quite soft
G`Day All iam now in middle of modding my Front Bar stock,i have found another nissan bar to cut up & replace the crap in centre of the bar i shall take Photo`s as i go,but iam one for STANLEY KNIFE Tape all that your going to cut so you can follow LINE`S,I did price someone else to mod bar & when told $300/$350 i said thank`s will try it my self,cheer`s chuckie.
  RED513 said:
How thick is intercooler?
My Greddy 75mm fits with slats (even thou i cut 'em :happy: )
Keep The Vertical slats!
It's just over 80mm, but also where the slats are is where the silicone hose
kinda buldges out, so they have to go...
thin ones they go through pretty quickly....thanks for everyones ideas :thumbsup:
My Greddy 75mm fits with slats (even thou i cut 'em :) )
