Hey Guys,
I have sitting in my yard (needing a home),
r32 GTR half-cut, engine (done 73xxxkms, compression check of ~158 across all six, welcome to come and test yourself's), gearbox, twin plate clutch, ECU and loom, dash, instruments.
Welcome to come and inspect.
Chasing $6000 for complete half cut.
Also have complete rear end for GTR R32. Cradle, diff, hubs, axles, brakes.
Chasing $1100 complete.
Front complete knuckles $300 the pair.
Front LCA $400 the pair.
Front axles $150 the pair.
Front radius/castor arms $250 the pair. (Adjustable's)
Front upper camber arms $300 the pair. (Adjustable's)
Few other bits and pieces. Located in The Gap, Brisbane, QLD.
Please don't hesitate to call me on 0431657139 Jason
https://www.sau.com.au/forums/topic/281739-r32-rb26dett-gtr-half-cut/
3K for the whole lot mate
jesus there's some orportunistic types out there.
Try to get a front cut from the importers now, with the exchange rates they are not bringing in any stock, and when they do???, it's selling for 6k plus, and it tired and old and worn.
Try Joe at SSS automotive in Sydney, that's a bit closer to you in Melbourne I'd say
Im selling a r32 gtr front cut here in Brisnabane ( sorry to hijack buddy) I reckon 6k is pretty fair, and I'm negotiable too, but not for anal rape
You could just go and buy a whole r32 gtr car for like 10k if you can find one????
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
