I got done by TOG's on my p plates.. 45km/h over the limit, over taking double lines, no p plates... and defect but they didnt say anything about no P's.. guess they had already ****ed me enough for one night tho!
I have heard of a few people having trouble.. but the majority are fine.
ive had my car for nearly 2 years on mt p's do a search for my 1st experience with them 100% positive,....5 more days and im cool! :P although i should have gotten of them 6.95 months ago :P you can always "detune" it by how many rwkw it'll take to get it to the legal limit... its vfery easy and can be taken back to standard from in les then 3 seconds ;) pm for futher info :)
heheh maybe i should drive round there next time im in melb.... ill laugh at them
amazingly cops dont trouble me... neva even ask to look under my hood or nothin
i even had a cop go round the back of my car with it idling,... was loud at midnite... cops didnt say a thing bout it... its over da limit tho
ahhh nsw cops r good :(
Nah, KW restriction.
Bah, how can they prove it?
a chassis dyno? I think not.
You can get that many different readings/fudge firugres it's not funny.
Just because the manufacturer 'says' it puts out 'X' amount of power. Doesnt allow for a 'tired' motor (not that RB's get tired easily) But you know what i mean.
There are a 100 and 1 different excuses.
To prove their point they would have to use a engine dyno i would imagine. Chassis dyno's just aint accurate.
I'm not worried at all. I make more at the wheels than the motor factory makes at the fly (like most sky's :() Wont bother me at all.
And ever noticed a lot of 'P' platers driving 5ltrs?
they are illegal too... but coppers cant do a thing. They can 'try' but it's too easy to argue and 'prove' them wrong
cops hey. let me jst say this.
28 tims in 49 days in 3 differant towns. hows that for being a hastled p plater. easiest way to get on with your life is not to do anything rong. they must think im an alcoholic (spelling) i get breatho nearly every time only ecause theres not much they can get for. the best comment heared so far by a cop is. we dont want anotherone of these cars in Mt Gambier and we especially dont want a P Plater owning one. >-(
dont do anything rong and all you'll get good at is blowing in a breatho. other then that your mate should be ok. :(
hmm i think a trip to my gambier might be in order :(
gimme a cops number so i can tell them im coming muhahha
i hate cops, 9/10 times they wont do anything for u, only themselves and their bosses that have had their **** sucked too many times
Originally posted by DJ984
Where are there engine oputput restrictions for p-platers???
I've got green p's on mine and neva had a single problem....
Dude... Hence this being a VIC thread... it's related to the VIC road rules :(
Has nothing to do with NSW and their Equivalent of Vic Roads
Originally posted by DJR33
i got done at knox city for being on p's. highly unfair circumstances, so try to avoid if u can, altho im DJing there every sat now so i dunno what im gonna do
I live near knox, nice to know they are gonna hassle me when i get my car :( i go there everyday for the gym.
where abouts do you DJ?
Originally posted by Raikkonen
I live near knox, nice to know they are gonna hassle me when i get my car ;) i go there everyday for the gym.
place called switch lifestyle at knox city
im resorting to taking another car. i dont want to risk being done again. especially by the same cop who said id lose my license if they got me again. even tho i know he was bulls***ing.
talking about knox, i got pulled over there as well, first thing the cop does, "pop the hood".
luckly i have a NA so he couldn't get me for it as im on my p's.
i wondered about detuning a gtst, and getting a dyno readout that said it was legal and just keeping that in the car.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
