Hi Guys,
Seen a few threads on here but really just wanted some clarification from the experts and I know that the GT3076R is quite a popular upgrade for an rb25.
Looking at putting one on myself, but there's 2 different options.
Apparently Garrett released a GT3076R part no (774067-5001) and it has a T04S 4" bellmouth comp housing, specs below -
Turbo Family: GT30
Turbine Inducer: 60.0mm
Compressor Inducer: 55.0mm
Compressor Exducer: 76.0mm
Compressor A/R: 0.70
Turbine A/R: 0.82
Bearing Type: Ball Bearing
Bearing Cooling: Oil & Water
Pic listed on their site for this particular turbo -
And then there is the other Garrett option - GT3076R (aka HKS3037S) part no (700177-7)
Turbo Family: GT30
Turbine Inducer: 60.00mm
Compressor Inducer: 57.00mm
Compressor Exducer: 76.2mm
Compressor A/R: 0.60
Turbine A/R: 0.82
Very slight variances apart from the 0.70 A/R compared to 0.60...
I can get the first one for around 1650, and the one with the anti surge (700177-7) comp housing for about $300.00 more..
Going a .82 ext gate option, has anyone tried the first one? and results?
Edited by evsr31
The part number for the port shrouded turbocharger one is 700382-12 , 700177-7 is its cartridge number - basically the center section with both end housings removed .
This is my opinion based on my research and hundreds of peoples findings all over .
The surge ported one has the more modern compressor wheel and is the same era technology as its turbine wheel . What people call the S wheel is a "T" series wheel designed to work with T era turbines .
That aside the cheaper one with the "S" compressor has a larger bulkier heavier compressor housing so it's a bit more difficult to package . If nothing else weight and bulk are best avoided where possible .
There are a lot of reasons why the surge ported GT3076R is the superior unit and there is a weeks worth of reading on this site just on these units .
It the cost was the only criteria you buy the cheaper one - and regret it ever after . $300 is a tidy sum of money but it's chicken feed compared to buying an inferior turbocharger and having to right the wrong . Those wise to the topic won't want to buy the inferior turbo no matter how new it is and the only cost recovery strategy is selling to a newbie or cost cutting to get rid of it . So lets just say you resell a now "used" turbo for several hundreds less than you paid for it and have to wear the cost of the new more exy better turbo .
So with the real GT3076R you get a better compressor wheel in a lighter more compact compressor housing AND you can use any of the available Garrett or HKS GT30 turbine housing sizes ranging from 0.61 A/R to 1.12 A/R and it shouldn't surge .
Search GT3076R and GT3037 and take note of people who have real world experience because they've been there done that .
I'm cooking up , if I can source the bits , a slight variation of the GT3076R which is all Garrett parts and no sneaky back yard BS . If you can wait a little while we'll see if it gives the desired results . If not buy the real GT3076R and know you have one of the better "GT30" family BB turbo options .
Over to you , cheers A .
Edited by discopotato03
Cheers mate, I was hoping that you would post in this thread. That has cleared up everything.
I will be going a .82 ext garrett housing, supporting mods (z32 afm, 600cc squirts, 38mm gate) and eventually cams to help with the lag issue that would probably be expected with the bigger .82 housing.
just to give you an idea my 3076 hits full boost (19psi) around 3600-3800 depending on load. may sound laggy but it really isnt once you drive it. down low i actually prefer it to the stock turbo. mynes on stock manifold with internal gate btw, so with a good manifold and external gate you should decent boost even earlier
I just bought myself this a few weeks ago.
Some people i have been speaking to in the SA section say that this turbo is too big for a RB25, and that it is going to be real laggy. But i wont really know for a few weeks till i have it installed. That is the 0.82 rear housing i think, it has it stamped inside somewhere.
  • 2 months later...
I got mine on a few weeks ago, see's full boost around 4k rpm. It is running 15psi and the car is making 265rwkw, boost hits pretty hard....love it. As it is spooling sounds like a jet.
full boost at 4k sounds abit laggy
is it an internal gate
when i had the internal .73ar it was laggy but still full boost before then
with my external mine hits 18psi around 3200 - 3500 (.82ar) and thats with a .5 bar spring with the gain turned up on the EBC to crack at 14psi
so its way more responsive then the internal gate
I think it will get better still when I put in the 1 bar spring
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
