IanB Posted August 3, 2009 Share Posted August 3, 2009 Hi all Im chasing some braided lines for my RB26dett and am curious as to if anyone knows of any kits? I had a hunt around on the web but couldnt find any. I suspect the problem comes from the fact that the twin turbos share the same water source which would make it difficult. Regards Ian Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/ Share on other sites More sharing options...
Moodles2 Posted August 3, 2009 Share Posted August 3, 2009 Try uniqueautosports , usually do alot of different types of braided lines for skylines Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747021 Share on other sites More sharing options...
Johnny Posted August 3, 2009 Share Posted August 3, 2009 I wouldnt mind a set when i do my turbos; does anyone have a take on the quality of the stock lines??? i ask cos in my s15, the water line cracked and leaked water while driving. It didnt do it on idle only on load so it took a long time to find the leak. Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747055 Share on other sites More sharing options...
IanB Posted August 3, 2009 Author Share Posted August 3, 2009 no good UAS couldnt help me Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747058 Share on other sites More sharing options...
R31Nismoid Posted August 3, 2009 Share Posted August 3, 2009 Most of the time it'll be custom only mate - most setups only going to braided lines with highmount because there is no factory lines on offer (as you would stick with factory lines if mounted in factory spots). So each one is really 'made to order'. Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747077 Share on other sites More sharing options...
PSI Parts Posted August 3, 2009 Share Posted August 3, 2009 We can supply you with all the stuff to make your own braided lines. See: http://www.skylinesaustralia.com/forums/Ea...ml Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747152 Share on other sites More sharing options...
Angus Smart Posted August 3, 2009 Share Posted August 3, 2009 i found some on the uk fleeeebay.. Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747167 Share on other sites More sharing options...
ali-turko Posted August 3, 2009 Share Posted August 3, 2009 here is what your after one kit if for oil and the other for water http://cgi.ebay.com/ebaymotors/Twin-Turbo-...sQ5fAccessories http://cgi.ebay.com/ebaymotors/Turbo-Oil-F...sQ5fAccessories Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747315 Share on other sites More sharing options...
OJR32 Posted August 3, 2009 Share Posted August 3, 2009 Has anyone run one of these kits? How are they for workmanship/reliability? here is what your after one kit if for oil and the other for waterhttp://cgi.ebay.com/ebaymotors/Twin-Turbo-...sQ5fAccessories http://cgi.ebay.com/ebaymotors/Turbo-Oil-F...sQ5fAccessories Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747599 Share on other sites More sharing options...
Travis Trayhern Posted August 3, 2009 Share Posted August 3, 2009 there great i have a set of there turbo oil and water also have the brake line kit to. Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747606 Share on other sites More sharing options...
GTR1993 Posted August 3, 2009 Share Posted August 3, 2009 I made my own out of speed flow. Works well. Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4747720 Share on other sites More sharing options...
whiteboy01 Posted August 4, 2009 Share Posted August 4, 2009 The water line kit above, where does it run from? Is it from the banjo bolt that comes from the hardline that runs accross the top that gets water from both ends (The one that comes round the back of the motor and the silicon hose that runs infront of the CAS) or does it replace this hardline as well? that seems like the cheapest option to get braided lines - thanks for the link! Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4748787 Share on other sites More sharing options...
IanB Posted August 4, 2009 Author Share Posted August 4, 2009 The water line kit above, where does it run from? Is it from the banjo bolt that comes from the hardline that runs accross the top that gets water from both ends (The one that comes round the back of the motor and the silicon hose that runs infront of the CAS) or does it replace this hardline as well? Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4748520 Share on other sites More sharing options...
kurosx Posted August 4, 2009 Share Posted August 4, 2009 (edited) hypergear on SAU does braided oil and water lines with speedflow fittings Edited August 4, 2009 by kurosx Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4749742 Share on other sites More sharing options...
ali-turko Posted August 4, 2009 Share Posted August 4, 2009 i bought the kit, just waiting for delivery Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4749473 Share on other sites More sharing options...
ali-turko Posted August 5, 2009 Share Posted August 5, 2009 i dont think the specific for an rb26dett or a full kit Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4750953 Share on other sites More sharing options...
Swiper the Fox Posted August 5, 2009 Share Posted August 5, 2009 (edited) I made up a kit using Earls fittings which replaced all the lines, including the hard water line along the top of the manifold...too expensive to make a kit and sell. Edited August 5, 2009 by DiRTgarage Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4751059 Share on other sites More sharing options...
whiteboy01 Posted August 10, 2009 Share Posted August 10, 2009 i bought the kit, just waiting for delivery Hey can you let me know how the kit is? Quality wise and fitment? Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4759569 Share on other sites More sharing options...
Gts-t Posted August 10, 2009 Share Posted August 10, 2009 (edited) Hey dirt, do u have anymore photos on different angles? cheers Edited August 10, 2009 by Gts30t Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4759585 Share on other sites More sharing options...
Beer Baron Posted August 10, 2009 Share Posted August 10, 2009 I made up a kit using Earls fittings which replaced all the lines, including the hard water line along the top of the manifold...too expensive to make a kit and sell. I would guess nearly $1000 of earls fittings and line there. does look very nice though. Link to comment https://www.sau.com.au/forums/topic/281753-rb26dett-braided-oil-and-water-turbo-lines/#findComment-4759700 Share on other sites More sharing options...
