got my kit today
quailty wise the kit looks good, all threads are correct
but one thing i dont understand with the kit is the banjo bolts that it came with,
the holes are a lot smaller, mainly the oil ones, the stock one has a hole of bout 6-7mm and the one that came with the kit is boit 2mm like a pin hole,
should i use the stock banjos??
or are they some sort of restrictor??
n mr kotter if you have ever taken off or put on rb26 turbos you know it can be a flamin mongrel, not only dose it look better but it make turbo removal alot easier :)
  • 1 month later...
Do Ball bearing turbo require less oil, therefore smaller banjos should be used as oil restrictors?
I am about to upgrade to ball bearing turbos and am looking at the same oil and water line kits, but just wondering if people have used the smaller banjos.
I have read that if you use the original larger ones it could cause the turbo to leak oil.
Any opinions?
Edited by gtr fan
Thanks TriniGT,
Someone in the above post said;
So it sounds like the banjo that came with the kit is a restricor. So this is what should be used for upgraded ball bearing turbos instead of the standard 6mm banjo bolts?
Hey Ali,
No didn't get anything further on this, however I purchased the same kit, looked at some others and spoke to a couple of people and it looks like the smaller banjo acts a restrictor.
But I was thinking to use the same banjo and put a restrictor from, which I think are about $15 each. These screw to the cartridge and then the lines in the kit should be able to screw to the restrictor (this is from the pics I have seen).
Either way I wouldn't just rely on the restrictor built into the turbo cartridge. It might be an idea to put an additional one on. The turbo will still be fed sufficient oil.
  • 4 years later...
  • 4 years later...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
