if anyone's used an injector cleaning service in sydney please let me know who/where and how much you paid approx. I need someone who can take the injectors out of the engine so preferrably someone who knows RB25s and won't take 4 hours to just remove them .. Then I need them cleaned/flowtested and chucked back in Cheers
https://www.sau.com.au/forums/topic/281792-fuel-injector-cleaner-in-sydney/
  • 1 month later...
ok Ive booked in this guy for thursday ($330 with him taking the injectors out and putting back in) will let you know how it goes..
M R J Mobile Injectors (Sydneywide)0407 664 531Send this listing to your mobileMobile Service
Carlingford NSW 2118
will do ... probably take a couple of weeks as I don't drive much so won't know if/how much it affects fuel economy etc. Besides my car's been running unusually well (heaps more responsive down low) ever since I changed my radiator and fan clutch recently so I dunno if I'll be able to tell the difference even if there is any in terms of response.
Speaking of which, I'm not sure if it's the new rad and/or fan clutch that are making my car run so much better or the fact that one of the mechanics at some point forgot to put 2 of those rocker dust cover bolts back in near the firewall and I've had a shitload of coolant leak in there all over my coilpacks/sparkplugs during bleeding. I'm sure it's dried off since but yeah that's when it started running so much better...at first it was rough and lumpy, then a while later ..like a new car, weird huh.
hey Dave, I assume you mean thermostat? Got a new Nissan OEM one which opens at 82C (bit higher than R33s etc but normal for R34 GTTs)
had to cancel on the injector thing ..been feeling sick as last few days, some food poisoning or stomach bug..Will reschedule asap though.
I had one of mine cleaned and one replaced, cost me 650$ all up, that was from local place and the guy wasnt 100% sure what was wrong so spent some time screwing around.
Hope that helps.
Edited by r33ftw
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
