I am sure a few of you have read my posts about trying to get my idle right on my M35.
6 months of trouble shooting, a bit of money tossed away (fortunately not too much) and many hours of reading and thinking of a solution I worked out that it was a faulty PCV valve. Nissan could not work that out.
For those of you not familiar with this item it is a Positive Crankcase Ventilation Valve (PCV Valve), and it's role is to let air/gas that blows past the piston rings escape from the crankcase. If it can not escape it creates a lot of pressure in the motor which starts to create oil leaks at gaskets as the oil is put under a lot of air pressure especially in a turbo car.
There are pro's and con's about this gas being recirculated back into the manifold after the butterfly as it is putting oily, petroled air back into the cylinders which is not ideal for the performance of the car. This is why many high performance cars opt for a catch can but legally you are not allowed to vent this gas straight into the air.
Anyway it seems the more I have reserched it is a part that is normally serviced/replaced at a major service inerval.
The effects of a fauly PCV can be varied and will largely not be visible when driving your car but some of the signs can be;
- excess boost bleeding off
- idle not resetting correctly
- high idle
The PCV should under normal operation should operate the following way.
1) At idle: should not allow any gas into the manifold.
2) Under light to medium throttle: Suck open the valvewith the high vacume of the manifold and allow gas to pass to the manifold.
3) Under full acceleration: The pressure in the crankcase will push open the valve and allow gas to enter the manifold.
If you are trying to reset your "Idle Air Volume Learning" with a faulty PCV it will not set the idle correctly, as it makes the car idle faster and does not allow the car to memorise the idle (sets only between 600-700). If your idle is not in this range then you may well have a faulty PCV. (it is soooo niceeee haveing a car that idles at 625rpm :) )
The part number from Nissan is 11810-8J102.
Cost is about $50
Not generally held in stock and about 7 days fro Japan.
It is located on the top of the right bank (drivers side) near the front of the car. If you follow the metal intake piping from the throttle body to where it joins the rubber piping coming from the Intercooler, it is located just below this junction. It will have a pipe leading from the PCV back to the manifold (it is the one nearest the metal brace on the drives side of the manifold towards the cabin)(hope that made sense :) )
When I removed mine the valve was moving freely inside the the body, not only up and down but side to side. Whilst a new one will rattle when you shake it, it is not meant to move side to side.
I have spoken to a one other M35 driver who has changed his and he was shocked at how much less the boost bled off in higher revs.
I hope my 6 months of pain helps you guys avoid this pitfall.
Cheers
Andy
https://www.sau.com.au/forums/topic/281801-m35-pcv-valve/
Can any pcv valve be installed there? I just thought they all do the same thing dont they?
I definitely have to do this myself, same symptoms but not all the time.
I am not really sure if you could put anything else in there. My gut feeling is no, as normally Nissan would have substitute parts listed if not available and they did not offer any substitute.
https://www.sau.com.au/forums/topic/281801-m35-pcv-valve/#findComment-4747425
where did you get your info regarding to the operation od the pvc valve ? did you research it and the m35 works different to every other pcv valve ? and is it controlled electronically ? it could not function in the way you describe if not. and also a pcv valve and a catch can go in different parts of the engine ventalation systems
https://www.sau.com.au/forums/topic/281801-m35-pcv-valve/#findComment-4747427
I have just read the internet for general information.
You may be right that any valve will work but as I said, I am not really sure.
You are right in your description but I can tell you when it is not sitting right it can really stuff up your car.
I am not sure what you mean about the catch can but my understanding is that the catch can is used to filter oil out of the blow by gas before the air goes back into the manifold.
If you know better how the PCV works please enlighten us all.
Edited by andy65b
https://www.sau.com.au/forums/topic/281801-m35-pcv-valve/#findComment-4747620
the spring tension may be specific for a VQ25DET as we have positive manifold pressure, whereas every other VQ series motor doesnt (besides the VQ30DET)
so its entirey possible its different. however, FAST it and find out and post back in here!
and yes a catch can prevents the solid oil particles from re-entering the motor via the intake manifold. eventually the catch can would need to be emptied. but if your car can fill one within a few years, you have some problems.
the valve is also threaded at once end that screws into the rocker cover, so youd need one that fitted correctly there.
https://www.sau.com.au/forums/topic/281801-m35-pcv-valve/#findComment-4747831
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
