Hey i was wondering if someone could help me out with this wiring. ive got eveything hooked up except this one plug which is very different. it's the bottom of 2 plugs in front of the fuse/relay box. story is my previous 400hp r33 was written off in an accident so ive found a new one to transplant into. however this one was an auto and the previous one was a manual. ive since done the manual conversion. so to summarize, What is this plug, what does it do, and how do i fix this issue ?? any help will be greatly appreciatedwiring.jpg
Edited by RBNRG
https://www.sau.com.au/forums/topic/281809-rb25-fuserelay-box-wiring-help/
Simple, I had the same problem with my manual conversion.
Basically the wiring loom that goes back to the computer is different between auto and manual. You will need to get yourself an automatic transmission loom, plug it in to the fuse box harnesses and then re-wire it to make it work with the manual transmission.
Otherwise these things will not be working:
Speedo
Power Steering
Hicas
Oil Pressure gauge in cluster
Turbo Pressure gauge in cluster
I learned the hard way after taking it in and out of workshops for two weeks.
There is some information in this thread on how to wire it up, but my understanding is that its not exactly the same with the r33
http://www.skylinesaustralia.com/forums/Di...05#entry2606505
If you cant work it out yourself, give my mechanic a call, hes the one who sorted mine out. Im sure he will be able to tell you how its done.
Turbo Tune
959 South Rd
Melrose Park SA 5039
(08) 8297 1030
Ask for Mark
  • 1 month later...
