after three days of fone calls and searching i have not come up with factory torque settings for conrod end cap bolts nor the head bolts. I have down laoded the manual and can find neither just other specific bolts with specific number inscribed on the them. Could someone please poinr me in another direction or if possable inform me of correct torque settings thankyou!
Ryan
https://www.sau.com.au/forums/topic/281816-rb25-tourke-settings/
