Hey guys and gals,
About 9 months i got my baby, 1 of 2 dream cars, an r33 gtr (others a ford gt40... yeah i kow i can dream) :) anywho after a couple of months i found that she'd misfire at around 5k under max boost at stock, so after savng abit i took her to c-red and forked out abit for a haltech cpu and tune and it seemed to fix it, turns out it was missing the air filter plug thing and only one of my 02 sensors was working... Feeling confident i was fixed they bumped it up to 14psi on stock turbos and a remap. Dyno'd at 340 atrw:)
Noticed around a couple of months later that she was doing it agan, 5k under boost, mainly 2/3rd gear, nice jerk:( did a bit of study and found that the coilpacks can be a good cause of the problem, so i bit the bullet and got the mighty splitfres, cant go cheap on these beasts:D
Anyway today after the install drivin down row, changed from first to second, hit 5k again and to my dismay she jerked... WTF could it be, and it always seems to be at the 5k mark...
Things runnin through my mind:
- spark plug gaps
- too much boost on stock turbos
- too much exhaust gas for the stock exhaust...
Does anyone have any experience in fixing this and co0uld possibly point me in the right direction??
Edited by gunns
https://www.sau.com.au/forums/topic/281839-4000-and-still-frustrated-help/
Feeling confident i was fixed they bumped it up to 14psi on stock turbos and a remap. Dyno'd at 340 atrw;)
Rears? or alls? :) ..... GTR .....
I'll assume you've read this.
What kind of "jerk", like missfire, or like, broken nose over the steering wheel, blood pissing out everywhere, and call your mother because tears are running down your face ??
Could be a bad alty (only ever had one in all my cars, started hessitating occasionally a higher rpms, then more frequently, then at lower rpms, then finally gave in)
Could be alot of things, just depends on what exactly is happening at that 5k RPM mark, could be crank angle sensor, air, fuel, spark, ECU
ah at the rears, c-red have only got a rwd dyno.
Haha jerk as in missfire, bout a split second of nothing then it picks up again and keeps goin good right up to 8k with no probs. i have yet to have any problems below or above 5k, seems to be very specific. i get the spark plugs changed every service, 5-10k's so i can cross them off. i just read another thread similar to this (gotta love the search functon) where they were mentionin the wiring loom. I might give the mechs a ring tomoz and see what they think, but i think a loom might be the next on the hit list.
Ta for the quick reply
Wiring looms from the ignitor box to the coil packs is a common fault, because they're inside the valley cover and prone to heat. They usually run OK until you try to move them and they go crunch, then they're f**ked. Same with the ignitor box itself, sitting on top of the cover doesnt help a great deal, alot of people mount them onto the firewall.
Couldnt find any wreckers around my work in Welshpool that had any for me because theyre such a common f**kup, you can order them from JustJap, SlidingPerformance, maybe eBay, etc... or let a mechanic stretch your ass for it.
Wicked as, so from the sounds of it, wiring loom or ignitor box, or cas if im unlucky. im not mech savy so unforunatley so wont be able to checkthis for myself, sounds like ass stratching FTL :-(
I guess itwas a bit noob to think that going splitfires woud the ducks nuts and just magcally fix it
Im just over in Swan View if you ever need a helping hand mate.
Splitfires might be a setback now, but when the problem is fixed, you'll notice a difference for sure.
Ignitor box will be cheap as, wreckers might have an ignition loom (they do, just as soon as they arrive they sometimes sell out quickly), and theyre pretty cheap too.
Fixing what ?? Most replys here are just wild stab in the dark .. go look in the workshop thread and visit the 1 closest to you
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
