Hey guys/girls,
Does anyone know where i can purchase an aftermarket ECU system for an R34 RB25DE, either GReddy E-Manage or something similar?
My car is a non-turbo now, but i am going down the conversion path soon, so i wanted something that i could use now to get the most out of my NA, and then when i get the turbo it can be retuned.
Thing is wherever i look, people only seem to be selling them for 33's or GTR's. So would they be the same for 33's and 34's? I thought they had different looms, etc...
Also, what wiring harnesses would i need to get? Damn things get real confusing when youre trying to find out what you need.
And would it be worth getting the E-Manage Ultimate considering what im planning, or will Blue be suitable for my plans? Or if anyone has any other suggestions of ECU's...
Thanks for any help,
Martin
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/
get an Apexi SAFC... great piggy back that can be used for turbo or NA and when you go turbo just retune it...
thing is, you can easily get rid of it if you want to get a more specific ECU ie. Power FC or Vipec but in the mean time if you don't have $1600 for an ECU the SAFC is great and any workshop can easily play with it
hope that helps mate
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4747967
Yeh i had thought of the SAFC II, but i thought they were really only useful for changing afr?
Would SAFC be just as good as SAFC II? And where can i get one for an R34 RB25DE, as i said before, ive only found things for 33's and GTR's.
Maybe i will look into them some more, thanks for that man
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4748528
Ok, i did a search and the SAFC has been discontinued, can only get the AFC Neo now, i assume that is what you have Levi? So it will fit just about any car? It only costs around $450, so i think i might get that if that is the case.
The AFC Neo would still be suitable for my current NA and later down the track the turbo?
Thanks for your help guys
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4748650
SAFC's are a standard item and can be used across a large number of cars. I Have a SAFCII Neo in my R33 Turbo, was very cheap and only costs around ~$150 to tune.
It will only allow you to adjust AFR's, but in these low-power applications, it's more than good enough.
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4748622
Dont go for the greddy e manage ultimate i have it in my car, hyperdrive found it to b a pain in the ass to tune, and ive heard these days noone wants to no about them, plus i was told when wanting more power that the ecu wouldnt handle it. also was told that nissans dont like them more sutiable for hondas etc. would def consider vipec if u got the cash
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4751693
They definitely do Nistune for skylines.
It's R33 GTSt's that they can't really do (they can but they need to use an R32 ecu).
If they can do my Neo engined auto stagea then I don't see why they can't do non-turbo Neo'd 34.
Ring Hyperdrive, CRed or Allstar.
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4754322
what is ur plan on ur car?
if you have big plan DITCH EMANAGE or any PIGGY BACK like SAFC is not worth it.
get a propper ecu, it cheap now days for Power FC 2nd hand.
emanage and safc is good only for small tuning, fixing AFR and up the boost by a LITTLE bit.
once you start getting bigger turbo, up to higher boost, changed injectors and soo oon, they cant do it any more, and it will shat it self and ruining your engine
i've blown 2 ENGINE on emanage and NEVER GO BACK any more ... Stand alone is the way!
ALLSTAR, RPW, HYPERDRIVE this the work shop that i went and talk about e-manage and THEY did not RECOMENDED to install on any car that Medium to Heavily modified. They will tune it for you but you will waste your money on the tuning as its TIME consuming and hard to TUNE E-manage to get it right, smooth graph and spot on + you wont get the results you want
for Stocker that wants 15-20 whp more yeah it will do it.
Edited by runsirebo
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4756218
Plan for the car is to turbo-charge it either next year or the year after. I will only run small amounts of boost, ~7PSI until i get the R34 GTR. Then my current car will become my project and the GTR will be my daily. I plan to forge the internals, rebuild everything, and thats when i will upgrade to a larger turbo
https://www.sau.com.au/forums/topic/281847-greddy-e-manage/#findComment-4756425
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
