Hello all,
Skylines Australia ACT have been extended a personal invitation from Ultimate Tunes to attend a new event that will be taking place in Phillip on the 5th of September 2009...
This looks like it could be a great event for local Jap car enthusiasts and will surely grow in popularity in the coming years... So lets show our support! :)
I have been told that there are limited spaces for the show and shine (60 in total) and there has been quite a bit of interest from other local car clubs already.
So put your hand up (or name down) if you are keen on attending the FREE Show 'n' Shine and / or DYNO Challenge so that we can get some idea of numbers.
Also - there will be prizes and giveaways on the day for entrants to the Show 'n' Shine and the DYNO comp, so as the ad says - start polishing your ride!
I'll start us off...
1. Bullet32 - Show 'n' Shine
https://www.sau.com.au/forums/topic/281878-jdmfest-2009/
  • Replies 104
Posted Images
I'll have a bash at the awd category but I aint got nothing at the rears compared to what some of those Supras are putting out there.
I might come down for a look but there's no way in the world I will ever put my car on this dyno ever again. I had a bad experience there the one and only time I was there and that's enough for me. I've forked out too much cash on my car to have it harmed on a dyno.
I'm not sure if there are any other Supra's attending though, I'm just down the road so I'll pop down to check out all the cars.
Cheers
Ross
https://www.sau.com.au/forums/topic/281878-jdmfest-2009/#findComment-4752890
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
