I am thinking to update from T04Z to T51SPL..
With fully stripped chassis and with slicks how low time will I do with my car?
Can I will do 9.0sec? Or it is too low for this power? What power I need for 9.0?
I did 11.2sec with very bad 60foot 1.75 and with terminal 134mph with t04z 30psi and with full street interior.
https://www.sau.com.au/forums/topic/281895-1000hp-rb26-s13-what-time-can-do/
  • Replies 53
Thanks for your reply!
Ok sure I will learn to drive it better but the t04z power can put me at 9's as you said... But can do very low 9?
I don't think so :P
So I am thinking to put larger injectors, t51 spl and new exhaust that will exit at front fender side.
Do you think that if I will do this setup I can do very low 9sec?
Something else do you think that I need?
I will put also full rollcage, front runners and I will strip everything of the car.
Weight of your car would be nice... As far as i can gather a stock s13 with engine/gearbox conversion of a stock rb26 would weigh about 1250kg compared to just 1170kg of a stock sr20det s13. Then i suppose you can add on some more weight for a larger turbo setup, more weight for fuel (not counted in dry curb weight) and then with any sense take some weight off because you would have removed HICAS on a drag car... right?
lets say your car weighs 1250kg anyway for arguments sake....
On a weight vs Horsepower @ wheels calculation you would be in the 8.2s range... with 1000hp @ wheels
Then take in to account the traction on your previous efforts and your terrible vehicle control and try and finish without hitting someone else would be a good goal. If i were you id leave your turbo setup as is and get the best out of that.
With that weight and lots of traction and good control you could get a 9 with around 600hp @ wheels according to the calculator which is not perfect but...
Edited by GT-RZ
Also the car will full stripped as now will be drag car..
With 600whp that sure I have now I am not sure if I can do so low as you say..... :P
I did 11.2 with 1.75 60foot!
Ok sure I cannot do better launch than 1.5 with et streets!!!!! In an other race I did 1.5 in a decent dragstrip!
So how much better than 11.2 with 1.5 launch?? I was thinking that I can do 10.5 at best!
My terminal I think that it is good... 134mph!
I will prepare a new s13 chassis for drag car and I will stay with my setup for some races... but I don't think that I can go neighter for high 9!!
And I want very low 9 :)
T51 SPL can make 1000hp flywheel!
With 850whp what time gives your calculation with 1250kg?
I dont think the part that you have installed between the steering wheel and the seat can run a 9. hell, it cant safely run an 11.
forget about the bigger turbo, and focus on upgrading that.
i think your should turn the boost down to say 20psi, sort out the chassis, sort out ur driving! sort out the tune. get the thing running consistantly and safely.
once this has been done then start to increase the boost.
then and only then, once you have lots of experience with your current set up should you even consider moving to a larger turbo.
1250kg with 850hp @ wheels is 8.6s
Keep in mind these are examples and theoretical outcomes given perfect runs and perfect grip... Not to mention you should be adding the weight of yourself in to the equation.
Here is the online calculator http://www.race-cars.net/calculators/et_calculator.html
You can crunch the numbers yourself and take in to account traction loss etc but it requires effort and that calculator does not. have fun.
PS: when you get your car tuned next get them to weigh it with you inside and everything else you will race with, then you know.
The bloke has an RB26 powered s13, he took it to the strip (which was not perfectly prepared, granted) and he started to get fairly untidy around mid-track.
Rather than back off for his own safety and that of the S2000 driver in the left-hand lane, he ploughed on and end up swerving badly into the other lane (possibly clipped the s2000) and caused the S2000 driver to hit the wall = epic fail.
A perfect example of plenty of cash, plenty of power but no friggin brains.
I ask how to make 9sec! I have mam and dad to protect me to don't kill anyone or to kill myself!
Jesus it was just accident!
Put the car away until you grow up mate- Mum and Dad shouldn't have anything to do with this.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
