  • Replies 53
Oh God!
THIS IS JUST SPAM!!!!
I crashed!!!
OK I CRASHED!!!
And so what???
Because I crashed I don't have skills to do 9sec? Wow!! Thanks specialists-judges-experts-consultants-assesors!!
Just try to see why I crashed..
I have done many races.. WHY NOW I CRASHED??
I am so unable to drive it straight the car with 800hp or it is something other the problem?
WHY MY CAR DRIFT AFTER THE 1/8MILE???
WHY MY CAR DON'T STOP WHEN I PUSH THE BRAKES???
SEE THE ROAD.... SEE THE BUMPS-HUMPS OVER 1/8MILE... SEE THE NON-EXISTENT GLUE AFTER THE 1/16MILE... SEE HOW MUCH DIRTY AND DUSTY WAS ALL THE ROAD!!!
MY WRONG IS THAT I DRIVE IT AS I WILL DRIVE IT IN A DECENT STRIP! BUT I WAS IN A MOTOCROSS RACE!
If I was in a decent strip I will do the accident??? NO
After this accident this drag strip closed untill will constract new surface!
It wasn't my fault.. I GO THERE TO RACE... NOT FOR A WALK!!!!!!!!
Also I was so nervous because I couldn't do good 60f because the glue that there was untill 1/16 was so bad prepared... so I put 7.5psi at my tires and with theese bumps and humps the car was dancing like a bitch!!
So stop to comment the accident... if you are better do better times for me in this f@cking bad strip!
Edited by GreeceS13
To blame the drag strip for what happened is nothing short of fanciful.
It was the combination of...
- You kept the boot in
- The tyre combination was WRONG (one of the main issues)
- Inexperience driving a car with such power
... That you had the accident. Stop blaming everyone else and look in the mirror because that is where the blame lies.
To then say you need more power when you cant even run a time that a 500hp car can run...
sigh.
Oh God!
I crashed!!!
OK I CRASHED!!!
And so what???
Do Not dig yourself a bigger hole. Have you no hazard perception>? really lets be honest for a second if you really knew this strip was unsafe then why would you 'drive it like a good strip'. You are making things worse. Accept your at fault, accept that you owe that other driver. Then do yourself a favor and rectify the problems be it the track, car or your technique.
I think if you originally came on here and exposed your crash and your lack of judgment/experience and were horrified at what happened and did not immediately blame it on everything except you! Then a couple weeks later ask about more power people would be looking at you in a different light. But you didn't and the best thing you could do IMO is keep quiet for a while :(
Oh God!
I crashed!!!
OK I CRASHED!!!
And so what???
If the track was so bad first of all why'd "you still drive it like it was a decent strip" when you knew it was'nt?, when it comes down to it whats done is done,
But dont blame "motor cross drag strips",The S2000 was doing fine it didnt look it was "dancing like B*tch" until you smashed into it,
Anyway listen to some of the advice on here either sell your car or fix your set-up (brakes,suspension,chassis,handling!!!etc)
You say you went there for race not a walk!!! you sound immature when you get behind the wheel your not just risking your own life but everyone elses around you, If you killed the other driver is that what you would have said to her family? "Sorry your daughter's dead but i went there for a race not a walk!) Mate wake up!
I seem to recall a few less powerful cars losing control at the motorplex (supposedly one of the best tracks in Oz) after making the same mistake of combining the wrong tyres. If memory serves one was a moderator on here at one stage?
But let the bandwagon continue...
Even the best can lose a car in a race.
but in saying that, you need to learn to crawl before you can run, this is where your experience is learned. To just jump into a car like this without knowing what to do is like giving a loaded gun to a child to play with, sooner or later you're going to die.
Anyone could see that he should have backed off and got the car under control before mashing the pedal again. Experience would have taught this, especially on this shitty track.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
