Hello,
I have just been told that I have to take out my Microtech ecu (cops) and was looking at the nistune option. What my question is are they a good option to go for knowing that i will be checked for to see if my ecu looks stock. Is there many of them being used. my car is a r33 s2 (auto)
Mods so far are FMIC, full exhaust, splitfire coils, did have a Eboost2 boost controller but also had to be removed & a Hypergear hyflowed turbo. I am looking to get back to the power i had before when i had all my parts in. Any help with this will be very helpful :thumbsup:
https://www.sau.com.au/forums/topic/281946-nistune/
  • Replies 46
Put the standard ECU in, get it checked over (defect cleared?) then put the microtech back in?
Do cars in victoria regularly get checked for aftermarket management? Or is it really obvious (hand controller visible?)
Was going to say with the mods you have the nistune would probably be a better option than the microtech. Sell the microtech should cover the costs of getting the nistune installed and tuned.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749288
Had my gtr for 7 or 8 year and have never been checked :happy:
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749441
It isnt? I thought it still was in Queensland? lol well thats a load off my mind
They are aligning with the national standard in 18 months but if you get a blue plate now and it has written there that you have an aftermarket ECU, in 18 months when they introduce the standard, you will be ok to keep it. Anyone after the standard is introduced will not be able to have an aftermarket ECU fitted.
There is currently no emmissions testing in QLD so for the time being we are safe. I got this info from DOT and the guy who writes my blue plates.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749582
Its funny how cops can find and EPA you on a high flowed turbo, which they are just identical looks to any other stock turbos. I also had a customer who got defected in Vic over a high flowed GTiR turbo that we worked on. I really believe they have X-ray eyes or some thing to looking through metal housings for bigger wheels.
Nistune is good and cheap. You can get away from most of cops with it. But I don't think Matt have made one for R33 yet. Most people I know is running off a R32 ECU with modified loom.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4751777
Nothing available for R33 yet, as far as I was aware it is plug and play with a 20 ecu, its just that you loose the variable valve timing, but I think its only series 1 that might be plug and play as series 2 has the ignitor in the ecu where the Rb20 does not.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4752189
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
