  • Replies 46
not sure about other states
but here in S.A ap engineering model power fc is legal nothing else thou.
and at regency even if your turbo is standard and they see braided line they will do you for a/m turbo, al thou i have seen some get threw .
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4754241
he (and Toshi in Sydney) remap R33's and 34s ... bit different to Nistune. I believe Nistune is more adjustable ..works with bigger injectors etc where as "remap" is only AFRs and ingition timing adjustments..
Remaps can handle bigger injectors, afm's etc.
My RB30DET was running a remap with z32 afm and 550cc injectors.
The difference is that Nistune is live tunable via the consult port, whereas a remap is tuned with a romulator (usually) and then a new EEPROM is burnt.
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4754331
No actually the remap stuff is done live also. Dr Drift developed the system to be able to do this.
Has been doing it long before Nistune even existed
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4754460
speaking of consult ..anyone know any nice programs to use ? I'm getting my consult cable today ..can't wait to see all the sensor data and crap :) Speaking of which, is there perhaps a summary of correct sensor voltages anywhere ?? eg. I wanna make sure my AFM, knock sensor etc are operating normally
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4754742
Sorry, maybe live was the wrong choice of word. I meant that remapping (at least how mine was done), is they solder a cradle where the old EEPROM was (I did this myself, saved a bit of coin) and use a romulator (chip with a cable) to tune, once happy with the tune they burn the maps to another EEPROM and chuck it in.
Nistune is tunable through the consult port, you don't need to open it up and remove chips.
speaking of consult ..anyone know any nice programs to use ? I'm getting my consult cable today ..can't wait to see all the sensor data and crap :/ Speaking of which, is there perhaps a summary of correct sensor voltages anywhere ?? eg. I wanna make sure my AFM, knock sensor etc are operating normally
I use Datascan on my carpc, cost about $35 from plmsdevelopments.
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4754962
The nistune guys REALLY need to get onto the R33 gtst computer. My thoughts is that if they don't have it ready by now they never will, must not be possible.
I thought it was, but the boards were very expensive?
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4756634
both false.
No aftermarket computer is legal in South Australia
After market lines are fine.
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4756655
Im using a Z32 ecu on my R33 GTST S1, only thing needed to be done was to change the order of the injector cables, that and joining 2 wires into 1 for the AFM signal, since the Z32 has 2, easy as pie :down:
I've been running stock S1 turbo, 3" full exhaust, HKS airfilter+piping, FMIC etc etc and done the tuning myself, i couldnt be happier. Also since i have an aftermarket thermostat that opens at 70 degrees i changed the enrichment per temperature and so on to match the mods of the car.
AFR 15.2 at low load for fuel economy, 13.5 when turbo starts boosting and 12.2-12.5 on full load/higher revs. Havent had tme to get it dynoed yet but way better then stock :P
I think you'll be very happy with nistune!
EDIT:
Why i went with the Z32 ecu instead of the RB20 is that the rb20 doesnt support VCT, the Z32 does.
Edited by brother_david
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4757164
Nothing available for R33 yet, as far as I was aware it is plug and play with a 20 ecu, its just that you loose the variable valve timing, but I think its only series 1 that might be plug and play as series 2 has the ignitor in the ecu where the Rb20 does not.
oh god, not that again. the r33 series 2 ecu does NOT have the ignitor built into it. it is built into the coils. that is why you can't run s1 coils in a s2 and vice versa, yet you can run a s1 ecu in a s2 and vice versa.
speaking of consult ..anyone know any nice programs to use ? I'm getting my consult cable today ..can't wait to see all the sensor data and crap :D Speaking of which, is there perhaps a summary of correct sensor voltages anywhere ?? eg. I wanna make sure my AFM, knock sensor etc are operating normally
i use ecutalk. i also have datascan and scantech but find ecutalk the easiest as far as just displaying info goes. the others have the the diagnostic tests though. it's always fun driving along then switching off a cylinder, LOL
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4761743
We have been doing quite a few epa cars latley with nistune (Nistune is the easiest and IMO the best EPA option) BUT a competant tuner can get a microtech through the epa polution process aswell (it is difficult though). I just did a FC rx7 with a microtech and even without the air pump passed its emmisions test.
Edited by URAS
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4761791
$655 with Nistune fitted for R33
http://www.k-tune.com.au/Parts_For_Sale.ews
I doubt it is re-pinned internally you still need to swap the 10 or so wires in the connector :D
Edited by URAS
https://www.sau.com.au/forums/topic/281946-nistune/page/2/#findComment-4761799
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
