PM me for pics of body coloured...
i) front lip (changed from its former matt black)
ii) side skirts
iii) rear pods
on my pearl black GT-R...
if it helps you to decide that you'd rather the C/F instead!
Tez
Pics sent to you with pleasure...
You can photoshop them with C/F and then select what suits you.
When you get the skirts/pods painted, they screw directly into the underside of the existing ones.
When you attach the rear pod, and because it's an elbow, screw in the corner screw first > then the others.
If you want to know where to get a NACA Duct, PM me.
thanks mate great help. Also did you install it yourself?
After painting, I let the panelbeater fit the skirts. They also have a wafer thin type of paper that can sit between the OEM skirts and the Nismo Z-Tune ones. It stops any abrading/scratching between the two painted surfaces (whilst you might take them off at some stage). Optional anyway.
  • 1 month later...
^^That looks quite good.
Have you seen DarkChild's R34 GTR?
Your car is similar to his with the carbon fibre but his stands out a bit more cuz his car is white.
- http://www.skylinesaustralia.com/forums/Updates-t278781.html
One of the best looking R34 GTR's with carbon fibre I have seen.
  • 11 months later...
finally got some pics for you guys of cf skirts n pods on my gtr.
can you tell me the size of the CE28N please "yes i know the tread is old"
are they 18 or 19
looks awsome in a Black GTR
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
