While we have a thread open and I can't be f**ked searching, which is the best (not necessarily the most expensive) lock kit to get?
I got mine from "New Parts" Section on Nissansilvia ages ago. from QLD seller. was $99, had all the parts easy to install. nice strong bar. wasnt a cheap hollow feeling.
som1 would know this.. my when i pulled out my Hicas system out i realised on the inside part where the tie rods connect to the hicas bar that my stock unit was Welded together.. would this be a method of stopping hicas? all related pipes and such were already removed.
Just learn to drive properly and Hicas is your friend. Then you don't need a lock bar.
He might be doing some track work and wanting some consistency there, Hicas isn't always your friend...
That's why I want to lock the HICAS. I've heard it's fairly unpredictable at certain speeds and I'd like to be able to control my oversteer without another variable in the already large equation.
I hear people say that all the time. I bet 95% of the people who say it have read it, but never experienced it. When Hicas does its thing, 99% of the time you don't feel it. If you're pushing hard and you do feel it, just go with the flow, it's certainly not un-predictable if you understand what it is going to do..
Why remove all that tech and development in hopes that a solid bar will do a better job, especially if has never been a problem for you. Don't remove it just because you read something on a forum somewhere, some clever little Japanese men put a lot of thought and money into designing a system that does some really clever things to improve handling and driveability. If a solid bar was better, Nissan would have installed it in the factory...
Unless you're trying to reduce the weight in the car, and you never plan to drive around corners (eg drag car), or you plan to do loads of drifting, save yourself the $$ and learn to enjoy the hicas.
Problem is, this is a computer controlled thing...and it's not constant...being dependant on speed and your angle of steering. Judging by the pic above it's just an unnecessary variable thrown into the equation. I don't want to get used to controlling it, as for the most part of track driving I can only see it being detrimental. I can appreciate the technology that went into it, but just like traction control and ESC, no thanks.
See I actually liked Honda's four wheel steer (atleast the one in the 2nd Gen preludes). It only operated at low speed so it made the things a dream to park (had to be careful of front wheel drive oversteer when booting through round-a-bouts) and didn't affect handling at higher speed.
That's what I thought HICAS was going to be like before I bought the car.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
