Hicas Lock Bar Installation
agentx
 Share
one of the workshops from the recommended section agreed to install it today. bit pricey (quoted 260 for installation only, i had my own lock bar) but that includes around 80$ of banjo fittings and hoses to reroute the hoses into the power steering pump instead of blocking the lines (which puts less pressure on the pump apparently).
Hopefully the jobs done good, picking the car up around 5ish today.
just got it back, the HICAS light isn't on and the steering feels exactly the same as before (very hard, sorta like no power steering) ... i know i need to get a wheel allignment done but will that make a huge difference all of a sudden? i thought it would be fixed by now :)
Did you tell the workshop who installed why you wanted it and if they thought it would fix the problem?
First thing i would be looking at is your power steering pump.
no I assumed its the HICAS since the light kept turning on and off and the steering got really heavy all of a sudden. I'll tell them to have a look at the pump if the wheel alignment doesn't help.
Do you have an aftermarket steering wheel, have been told that can cause the light to come on.
It's possible the HICAS light was coming on because the power steering pump was faulty and not supplying it with fluid? Meaning your HICAS was fine all along.
ok so $1300 later, i have the pump and an exhaust leak fixed :P lesson for other people out there, if there's a problem with your power steering (being too hard) ... its your PUMP!
ouch. My power steering has been removed, feels gooooooood.
Been there done that, had a problem with my car, after a week of running around and paying $500 for parts it turned out to be nothing to do with them and cost me another $500 for a mechanic to fix it.
$1000 in the hole.
I'm actually not THAT sad considering the car's running so much better and also, after a year of thinking the car's steering is just a bit heavier and not having driven a skyline before ... its HEAVEN steering the car :P but yea could've done the exact same work for 500 if i pointed the thing out earlier.
Now to get to the real mods :) SAFC put in and tuned to 14 psi
 Share
    • 100% this, no point delivering a steam oven when the client just wanted a toaster
    • The best part of my setup is, we only have two sites. Our head office where I'd put every thing has plenty of internet capacity. We're on a 200/200 dedicated fibre. Even better, there's only like 6 people in the office at most, and the other office has 2 people in it (likely 3 soon). The majority of our work is in a custom piece of software, as it is part of the backend of the system we provide to customers. For our arrangement, on prem would be wayyyyy easier, and a VPN tunnel site to site is easy for me to manage. Scaled at many many sites, or quite a few hundred employees it's starts getting a bit different for all people outside the head office. However, everything in the cloud becomes worse for the people who operated previously at the site that held the servers, as now they're at the mercy of their internet, and not GBPS internal network (f**k the idiots who hook a desktop PC up on WiFi or permanently sit at a desk using a laptop and don't go remotely with it).   It really does come down to the business needs and structure as to what is best. For us, 365 is mainly being moved to for office apps, moving email from Google to Exchange, and setting up "Active directory". Otherwise we have a ticketing system with support that runs on our own cloud system, or the sales process sits in a CRM we pay for. My biggest push back for having most of the shit turned off and saying no when people want new shiney things is "that won't meet our security requirements, or efficiency gains, so all you're requesting is money spend to open us up to security issues, or to make our staff less efficient" Which is funny when one of our core values is "To do more, with less"
    • Think of it as a fancy iFrame with the auth passed through to PowerBI as you're already authenticated logged into Teams   I'm the complete opposite, I hate everything on Prem, it's slow as shit, you need VPNs to get anything happening, then when you want on-prem DBs to talk to say PowerBI you need to install/setup data gateways to essentially VPN back into your SQL instance. I suppose from my perspective, on-prem sucks, but from an infrastructure perspective, your environment is somewhat air gapped to the web via your firewall(s), etc.   The curse of knowledge, the more you know the more you suffer. Farken philosophical shit.
    • Would you mind uploading the pics again in your steps?  It’s not showing up.
    • Wherever you ask them to. I had one added to the crossover pipe near the BOV as well as the hot and cold sides of the intercooler piping to provide greatest flexibility in measuring temperatures post-turbo. I have the IAT installed in one, and bungs in the other two.
