For Sale:
LATE 2004 MODEL SKYLINE V35 350GT / G35 PERFECT CONDITION MODIFIED - LOW KMS - NAV SYSTEM 30.000 Kms
A very good condition V35 is going into sale market, what you will get is a perfect condition V35 with late 2004 model, Low Kms, premium pack, with navigation, full leather interior and modified.
This car always been looked after very well, washed once a week, Always keep on shaded carpark without exposing much to the sunlight, always serviced every 5000kms, used BP ULTIMATE 98octane, Serviced history, New front disc brake and front and rear brake pads.
Very smooth car and pretty good on fuel, car is very clean inside and out. This car has a Very large torque/power that you can feel it straight from accelerating. Petrol consumsion has been very fair (great) related to the power you got.
This car has been modified to ensure the look of its aesthetic on the street and handling as well as power. All Stock parts will be given to buyer, anytime buyer needs to make it to stock, its just like a click of a finger.
Number Plate will not be included
Reason for sell : Moving Overseas
MODIFICATION
• FULL Leather Seats
• Pioneer Carrozeria Deck
• Pioneer Front Speakers
• Pioneer Rear Speakers
• Pioneer Carrozeria Navigation
• Pair of NISMO Front Floor Mats
• Nismo Rear Floor Mats
• 20'' Nkb Elite 8 REP Silver Polish
• Kumho Ecsta Spt Tyres 235/35/20 Front
• Kumho Ecsta Spt Tyres 275/30/20 Rear
• Tanabe NF Suspension
• Front Sport Disc Brakes
• Front and Rear Sport Brake Pads
• INGS+ Front Kit
• INGS+ Rear Kit
• INGS+ Side Skirt
• Sport Trunk Spoiler
• Infinity Front Grille
• Tinted Window
• HID 6000K
• MTEC Front light Bulb
• MTEC Trunk Bulb
• Black Roof Vinyl
• HKS Legamax Exhaust Catback System
• Apexi Air Filter Pod Filter System
• ARC Front Strut Bar
STOCK ITEM THAT YOU WILL GET
• Exhaust System
• Set Alloy Wheels with tyres
• Halogen light bulb
• Suspension set
ENGINE SPEC
• 3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35DE
• Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 18
• Multi-point injection fuel system
• 20 gallon main premium unleaded fuel tank
• Power: 209 kW , 280 HP SAE 6,200 rpm; 270 ft lb , 366 Nm 4,800 rpm
SUSPENSION SPEC
• Four-wheel ABS
• Brake assist system
• Four disc brakes including four ventilated discs
• Electronic brake distribution
• Electronic traction control via engine management
• Immobilizer
• Spacesaver steel rim internal spare wheel
• Stability control
• Multi-link front and rear suspension independent with stabilizer bar and coil springs
SAFETY FEATURES
• Electronic Stability Control
• 4-Wheel ABS
• Traction Control
• Adjustable Upper Belt - Front
• Pretensioner
• Energy Management Feature
• Rear Center Lap/Shoulder Belt
• Side Airbag - Front
• Head Airbag - Front
• Head Airbag - Rear
• Rear Seat Head Restraint
• Dynamic Head Restraint
• Tire Pressure Monitor
INTERIOR
• Leather-appointed seats
• 8-way power drivers seat with manual adjustable lumbar support
• 4-way power passengers seat with manual adjustable lumbar support
• Folding rear seat back
• Front seatback map pockets
• Rear window defroster with indicator light and timer
• Rear head restraints
• Illuminated entry system with time delay fade-out
PRICE : $39.500 DROPPED TO 35.500 - 4K cut off prices
Contact Number: 0430083799
CALL NOW, DON'T WAIT!!!
Thank You Guys
  • 4 weeks later...
Guest
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
