For Sale:
LATE 2004 MODEL SKYLINE V35 350GT / G35 PERFECT CONDITION MODIFIED - LOW KMS - NAV SYSTEM 30.000 Kms
A very good condition V35 is going into sale market, what you will get is a perfect condition V35 with late 2004 model, Low Kms, premium pack, with navigation, full leather interior and modified.
This car always been looked after very well, washed once a week, Always keep on shaded carpark without exposing much to the sunlight, always serviced every 5000kms, used BP ULTIMATE 98octane, Serviced history, New front disc brake and front and rear brake pads.
Very smooth car and pretty good on fuel, car is very clean inside and out. This car has a Very large torque/power that you can feel it straight from accelerating. Petrol consumsion has been very fair (great) related to the power you got.
This car has been modified to ensure the look of its aesthetic on the street and handling as well as power. All Stock parts will be given to buyer, anytime buyer needs to make it to stock, its just like a click of a finger.
Number Plate will not be included
Reason for sell : Moving Overseas
MODIFICATION
• FULL Leather Seats
• Pioneer Carrozeria Deck
• Pioneer Front Speakers
• Pioneer Rear Speakers
• Pioneer Carrozeria Navigation
• Pair of NISMO Front Floor Mats
• Nismo Rear Floor Mats
• 20'' Nkb Elite 8 REP Silver Polish
• Kumho Ecsta Spt Tyres 235/35/20 Front
• Kumho Ecsta Spt Tyres 275/30/20 Rear
• Tanabe NF Suspension
• Front Sport Disc Brakes
• Front and Rear Sport Brake Pads
• INGS+ Front Kit
• INGS+ Rear Kit
• INGS+ Side Skirt
• Sport Trunk Spoiler
• Infinity Front Grille
• Tinted Window
• HID 6000K
• MTEC Front light Bulb
• MTEC Trunk Bulb
• Black Roof Vinyl
• HKS Legamax Exhaust Catback System
• Apexi Air Filter Pod Filter System
• ARC Front Strut Bar
STOCK ITEM THAT YOU WILL GET
• Exhaust System
• Set Alloy Wheels with tyres
• Halogen light bulb
• Suspension set
ENGINE SPEC
• 3,498 cc 3.5 liters V 6 front engine with 95.5 mm bore, 81.4 mm stroke, 10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder VQ35DE
• Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 18
• Multi-point injection fuel system
• 20 gallon main premium unleaded fuel tank
• Power: 209 kW , 280 HP SAE 6,200 rpm; 270 ft lb , 366 Nm 4,800 rpm
SUSPENSION SPEC
• Four-wheel ABS
• Brake assist system
• Four disc brakes including four ventilated discs
• Electronic brake distribution
• Electronic traction control via engine management
• Immobilizer
• Spacesaver steel rim internal spare wheel
• Stability control
• Multi-link front and rear suspension independent with stabilizer bar and coil springs
SAFETY FEATURES
• Electronic Stability Control
• 4-Wheel ABS
• Traction Control
• Adjustable Upper Belt - Front
• Pretensioner
• Energy Management Feature
• Rear Center Lap/Shoulder Belt
• Side Airbag - Front
• Head Airbag - Front
• Head Airbag - Rear
• Rear Seat Head Restraint
• Dynamic Head Restraint
• Tire Pressure Monitor
INTERIOR
• Leather-appointed seats
• 8-way power drivers seat with manual adjustable lumbar support
• 4-way power passengers seat with manual adjustable lumbar support
• Folding rear seat back
• Front seatback map pockets
• Rear window defroster with indicator light and timer
• Rear head restraints
• Illuminated entry system with time delay fade-out
PRICE : $39.500 DROPPED TO 35.500 - 4K cut off prices
Contact Number: 0430083799
CALL NOW, DON'T WAIT!!!
Thank You Guys
  • 4 weeks later...
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
