I got my car back today and I'm very pleased with the result .
To rehash I contacted JB a couple of weeks back and asked for a road clutch to handle ~ 260 Kw in a warmed over RB25DEBT . What I effectively got was an OEM Daikin 250 mm organic plate from a Z32 300ZX TT . Normally R33 RB25DET's have a 240 mm diameter clutch but Jim knows how to put together a pressure plate assembly that can use a 250 mm plate on the std (resurfaced) flywheel . This was a new combination he was cooking up but in testing he found that in this form the pressure plate wouldn't fully release the 300Z plate . I wanted to use that clutch plate because he said its sprung center and lining combination is better than any of the aftermarket 250mm Nissan plates . The answer was to remove the facings from the Daikin plate and reset the wave springs on the backs of the organic linings .
The drive experience is very nice and as long as you do the usual 1200 odd rev take off alls fine . My flywheel was lightened a bit and faced of course , it was balanced by itself and then with the pressure plate assembly bolted to it .
Jim sent me a new genuine gearbox front seal and I bought a rear main seal from John Robinson Nissan Spares in Rockdale (Syd) .
After a bit of research I thought I'd give the gearbox synthetic oil to swim in and chose Castrol Syntrans 75w85 , according to Castrol's blurb this can go wherever VMX 80 can so based on this and with the Kids seal of approval in it went .
From what Jim told me the clamp (drive) load rating of this clutch worked out to be 2600 lbs and equates to good enough for 277 Kw - no idea how that's worked out and no reason to doubt his word .
So a big thanks to Jim Berry for building this clutch , Milton at Harris Engine services for the machining and balancing , Bruce at Exceller Steering for fitting it , everyone here for sharing their experiences .
Cheers and thanks , Adrian .
Sorry I don't have the paperwork for it here . It's probably with the people who got the other clutch kit from Jim as both were sent to them and I retrieved mine last Sunday .
You're probably better off contacting him because a few things were done to mine for reasons of functionality rather than price , like resetting the wave springs in the clutch plate set it back a day and cost labour to correct which was fine with me . An aftermarket plate may have made it right but I wanted the better sprung hub and best linings going .
I gave him a bell late this afternoon to give the promised feedback . I tell ya there is a lot more in clutches than I ever imagined and I would find it distasteful fitting an off the shelf kit from a generic local mob - for my cars anyway .
I know to some people a clutch is a fancy clamp that lets them change gears and the cheaper it is the better they like it .
Like a lot of situations in life things are not always as they seem .
Enough of that , cheers A .
Well nearly , nearly forgot .
The part numbers for the genuine front gearbox and rear crankshaft oil seals for my car .
GB - 32114Y4000AU "OIL SEAL" .
RM - 12279-5L310 "SEAL OIL CR/SFT" .
Actually Jim said that the above rear main seal part number is to suit 98 RB25's , my car is supposed to be a 96 S2 and it has the late TPS stuff but not the 97+ Neo type CAS .
A .
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
