Hey guys
im kinda new to the skyline scene, and certainly my knowledge is very limited. I was wondering whats a good coilover kit that wont cost arm and a leg for a R34 GT-T (Coupe). Be sure to shitcan the shit coilover kits so i can stay away from them =D Ive only so far looked @ the pedders extreme XA coilover kit for the R34GTT Coupes so i havent gotton very far in my research =[.
THankx
Az
https://www.sau.com.au/forums/topic/282111-r34-gt-t-coilover-kits/
unfortunately mate if you want good suspension your going to have to pay for it. if you want good brand new ones your looking at around $2,000. id be looking at tein superstreets they are what i wanted but i settled for second hand nismo s-tune instead. also it makes it more expensive at the moment because our dollar is weaker at the moment. you could also look at 2nd hand but then it is risky and you wont be sure if its good until you test it.
edit: i forgot to mention you might want to do a search in this section as well theres plenty of info that should point you in the right direction. but just for starters there are alot better ones than pedders. :(
well i know the aussie tein superstreets are changed to suit our roads, and then the jap versions will be a bit stiffer. but i know a few people that preferred the jap versions more.
im just going by what people have said and experienced because i havnt been in a car with them myself.
yeah, i've got bilstein shocks with whiteline springs. great setup (with adjustable swaybars, sus geometry kits as well)
if you haven't already, do the swaybars front/rear FIRST, then look at coilovers/springs.shocks.
  • 1 month later...
I have HKS coilovers in mine (sorry dunno which exact model) but they are pretty damn stiff and not really suited to alll of our roads here in Perth. But I think its a case of what you want, I like my car handling well and I don't mind a bumpy ride so thats good for me if you want something a lil softer, go the TEIN superstreets. If you want something that will give you great performance look Jap.
  • 1 month later...
I had silk roads rma8's in my s15 with a few other bits and pieces that was a DREAM to drive as the name suggests SILK such a smooth ride but so nimble, handled like it was on rails!
iv just placed my order today for some HSD HR's for my 34 4door cant wait herd nothing but good words! Also agree with skidjap a little bit steep but all good
Edited by Volk34
on the lookout for coils as well recently and the cheapest i came across is D2 (about $1.4k fully adj and has pillowtops), im considering greddy type S (2.8k fitted), tein super street for about 2.3k delivered and blistein PSS9... anyone care to shed some lights on the mentioned few? would be good for AZ and myself since we're in the market for new coils. :)
Just bought the Teins Superstreets after using Nismo R-Tunes for 4 years. One word, the Nismo is way much better than the Teins for performance and also probably can handle longer in the track. Teins is very very soft to my liking and cannot seem to understand why it needs 16 settings when anything above 5 clicks (from hardest setting) is way to soft to be considered performance coilovers. Do they really have Bilstein PSS9 for the R34GTT, that would be a nice shocks to invest in....anyone tried them before?
The PSS9 kit is actually designed for the R33/34GTR, so you can use it on the R34GTT. The only issue on the R33/34GT is that the rear springs ratea are rediculous as they were specified by the Japanaese Bilstein Distributor. They are almost double the rate that they need to be. On a R34GTT I would recommend also taking some spring rate out of the front, due to the lighter weight of the 2wd. The shock damping is OK, it will handle the change in spring rates easily, it has the usual Bilstein sophisticated valving and the adjustment is meaningful and effective.
Cheers
Gary
Cheers
Gary
Thxs SidneyKid for the feedback. I just wondering whether the PSS9 front height adjustment is sufficient since the GTR shocks is usually shorter. Previously found a 2nd hand unit HKS Hypermax II (GTR spec), fitted it but the front was too low plus after raising the height (springload was compress). That's why from now on I hardly look at GTR spec shocks anymore.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
