hey everyone
just one thing iv been thinking bout lately is the the stock denso supra fuel pump
that flow 330lph at 13.5 volts
now i bought a s/h nismo pump and ended up being dodgey i cant really afford to spend $550+ on a new one
so iv been looking in to these fuel pumps i can get them for bout $250 new
which i think is good value and out flows the nismo one by a far bit
there 51mm in diameter so same size as stock so shouldnt have to many drams fitting them
and denso is no shit brand or there not gunna fail like the walbros
whats ppls thoughts on these
https://www.sau.com.au/forums/topic/282143-denso-supra-fuel-pump/
These genuine denso supra pumps are really great units...i drive a supra now and researching them they have been known to flow enough for small to medium singles...lotsa guys running street setups putting out 300rwkw on the stock pumps...
Can i ask...where can you get them for $250 new? i've been trying to source them and get quoted over well above $400 for a pump...
heres details from suppler
Hi mate, pump flows 330lph at 13.5 volts and is 51mm in
diameter. Its made by KYOSAN japan which is a good O.E.M
supplier to toyota, mazda etc.
It is identical in appearance to the denso 51mm fuel pump. Has
also the same connectors as the denso. However flows more than
the denso as has a twin pump system. The denso only flows
220lph and this flows 330lph.
Its the highest flowing intank pump that we know of and have
ever come accross as we test all our pumps to see which are the
best to use in our customer cars.
This pump will have enough flow to supply as much, if not more
than an bosch 044 used with a surge tank (so saves you a lot of
money having to convert to a surge tank setup).
We have tested and know guaranteed that this pump flows over
300lph as thats all our test unit flow up to as there isn't a test unit
that will show over 300lph, most only go up to 200 - 250lph.
So guarantee that you wont be disappointed otherwise your
money back guarantee and comes with 12 months warrantee. We
don't sell cheap aftermarket products only the best genuine
performance products and test everything to perform before we
sell it and back everything we sell with a 12 month warrantee.
These pumps will retail for over $700, only reason we sell them
so cheap is because we are wholesalers and purchase in bulk.
So give us a call next week and they should be in.
thanks P.W
  • 4 months later...
Digging up an old thread, where abouts where you able to purchase the Denso and what was the part number.
Is it the Denso 195130-1020? Or was it the Kyosan pump (modified denso pump)? Thew flow figures suggest the later.
Cheers
...re-digging up an old thread...
Can the standard fuel pump controller in a R33 GTR be used with a Bosch 044 fuel pump? Or am I better off grounding it so the pump sees the full voltage all the time?
Cheers,
Mike
Ground it at a minimum.. measure the voltage you are getting at the pump afterward and decide if you need a larger feed, I did.. but considering you have a 33, you don't have the wiring run from front of the car to the back so you might be ok.
Edited by heller44
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
