Ive read through endless pages of dyno graphs and comparisons, ive even tried a few combos my self. but im after peoples recommendations as to what would be a good, over the counter purchase to put on my RB25.
I want around 270-280 with awesome response, with the potential to go to 300 ish. Turbo will be in a high mount application and more then likely externally gated.
i have previously run a gcg 3071R with .71 avo rear housing in the low mount postition internally gated and made 280 rwkw with cams and gears. wasnt a bad turbo at all. but i still felt it was a bit of a compromise being internally gated as well. boost control was an issue with this set up.
so yeah... post some suggestions people.
Cheers
Simon
find out what troy (roy) uses on his rb20 and run the same setup on your rb25det
from memory its a td06 from a GTR twin kit run in single form on a proper manifold, external gate
its here
http://www.skylinesaustralia.com/forums/Rb...o-t103095.html#
td06 20g-8cm2 rear housing
with a proper setup
yeah i'd love a TD06 20g, one of my mate has one on his 25 and makes 317 rwkw on 17 psi. awesome response too. however at 4K for the kit its a little out of reach.
after a garret option which would be cheaper yet still effective
You could either wring the neck of a GT3071 (with a 0.82 rear housing) or GT3076 or perhaps something in between like discopotato 03 just ordered ie 52 trim 76mm.
If you have a split manifold you could order a divided housing from ATP which might improve response slightly and would suit any of these options.
For about 280rwkws with fast response you can try a 52T 76mm comp on a GT30 Turbine in BB assemble using .63 rear housing. Or .58 rear housing which would definitely increase response shaving off about 20KWs top end power. You can also replace the standard .50 To4E compressor with a .60 T04B comp. Which can also increase turbo response.
have thought about tuning for E85 but availabilty issues is a concern for me as sometimes its not even for sale in SA. that and the fact for 300 rwkw i'd need 740cc injectors or bigger!
limpus: the 3037 pro s would be my ideal choice for a turbo i reckon. how much you asking?
I was thinking about this last night, 4k for the td-06 kit seems cheap when you consider what it comes with compared to a custom garrett setup.
this is a rough guide, for what I would do with a garrett setup, obvioulsy cheaper if you buy a china minifold.
decent manifold - $1200
turbo - $2000
wastegate - $500
oil and water lines - $300?
Custom Dump - $250-300 in mild steel
intake pipe- anywhere from $10 to 200
Mind you, if you can get a td-06 kit for 4k please let me know where lol
yeah thats the thing tho, exhaust manifold, dump, intake and oil and water lines i do not need to factor into cost as i'll be doing them all myself. So just need turbo and gate really.
that RX6 kit looks insane! lol
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
