1995 Series 1 R33 GTS-T
90,000 kms
Stock viscous LSD, pretty badly biased to one side.
284rwkw, and she kicks out like hell on accelleration.
Right now I can't afford a new Kaaz or Nismo mechanical but will eventually.
Can my stock diff be revived or improved a little by changing the oil and to another grade ?
Cheers.
90,000 kms
Cheers.
Yes you can.
Pull it apart and put a thicker shim on the side opposite the viscous coupling. I usually put a 1.4mm (thickest) as they are normally around 1.2 - 1.26(?) so it tightens it up enough not to be bullshit locked all the time but still really good.
how much is it roughly to shim up a diff?
anyone know?
Well the shim costs about $4. The rest is in your hands.
If you pull out the diff yourself (approx 1.5hrs) then it would take someone approx 30 minutes to throw it in.
If you pull out the diff yourself and do the shim yourself, then you pay no labour, just the $4
If you get someone else to do the lot, then approx 2hrs labour.
Yes you can.
this 1.4mm you talk of, how is it around car parks?
QUOTE (snappy_ @ 11 Aug 2009, 07:03 PM) *
anyone know?
hey snappy, i think drift garage charges $200-$250 to shim a diff and thats including evertyhing apart from the shim.
so thats taking it apart and doing the opposite? or just to install the shim?
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
