1995 Series 1 R33 GTS-T
90,000 kms
Stock viscous LSD, pretty badly biased to one side.
284rwkw, and she kicks out like hell on accelleration.
Right now I can't afford a new Kaaz or Nismo mechanical but will eventually.
Can my stock diff be revived or improved a little by changing the oil and to another grade ?
Cheers.
90,000 kms
Cheers.
Yes you can.
Pull it apart and put a thicker shim on the side opposite the viscous coupling. I usually put a 1.4mm (thickest) as they are normally around 1.2 - 1.26(?) so it tightens it up enough not to be bullshit locked all the time but still really good.
how much is it roughly to shim up a diff?
anyone know?
Well the shim costs about $4. The rest is in your hands.
If you pull out the diff yourself (approx 1.5hrs) then it would take someone approx 30 minutes to throw it in.
If you pull out the diff yourself and do the shim yourself, then you pay no labour, just the $4
If you get someone else to do the lot, then approx 2hrs labour.
Yes you can.
this 1.4mm you talk of, how is it around car parks?
QUOTE (snappy_ @ 11 Aug 2009, 07:03 PM) *
anyone know?
hey snappy, i think drift garage charges $200-$250 to shim a diff and thats including evertyhing apart from the shim.
so thats taking it apart and doing the opposite? or just to install the shim?
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
