Originally posted by SKYL9
each to their own but it sorta looks like your trying to pretend you have a 34
i was thinking similar when i first looked, must be the mis-matched sizing...
I though a lot of you guys preferred the Symetrical look of the same-sized 33 stove plates?
I think on black it would be best!
I think they replace the whole rear plastic bit - so not easy to steal.
Yeh, its kinda ripping off the r34 but hey - who cares :( also, it turns the centre brake light into the winker - thats what the wiring loom is for, so i dont know about the legality.
They should be here mid next week - so i can show u all in person sometime.
  • 4 weeks later...
AFTERBURNERS!!!!!! :) Grrrrrrrrrrrrrrrrrrrr
If they were colour matched to the car, i wouldn't mind them. As you said dave, unique. :)
