it only kicks in around 80kph as Aaron has said. its basically an electronic actuator (motor) that controls a steering rack attached to the back of the rear subframe and is liked to the rear of the wheel hub with a toe arm. on the R32 & S13 models it was a hydraulic setup driven off the power steering pump. it turns the rear wheels only by approx 0.7 deg from center, so if your where going around a right hand bend you wheels would be something like this:
front wheels // //
rear wheels \\ \\
when you install a HICAS lock bar you remove the actuator/rack and put a solid bar in between the two toe arms to hold the rear wheel toe where you want it.
edit: beat me with a much better diagram MIKE lol
Edited by QWK32
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4753292
HICAS is a very complex system, that is way over what most people think it is.
It helps to make a car feel shorter & more nimble, and helps to damp Yaw effect.
A long wheelbase car is easier to control but slower to turn. Rear wheel steering helps to turn the vehicle.
It has been heavily critisized for making the rear end feel loose, vauge and unnatural.
Lots of HICAS systems get taken off cars, mostly because owners do not fully understand what it is about.
It is there to make the car drive faster.
As you enter the corner the rear of the car actually gets kicked out, which reduces understeer, if you stay hard on the accelerator, as the car reaches the apex, the steering, G-sensors and throttle position will let the car "know" that it is at the apex, the rear wheels will come into phase and the car will steer straight though the apex, to take the fastest line through the corner.
It's kinda like taking a drifters line without drifting.
Your car should have the same system as the R34, which is also a model following control system.
It is pre-programmed to follow cornering models. It is not just feedback based.
If you really want to find out more about, and get a new admiration for our favorite car (sorry not the Stagea) get the book Nissan GTR by Alex Gorodji. Some of the above is taken from the book.
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4753764
simple diagram
i really hope it doesnt work that way, thats very dangerous!! if the rear wheels are turning in the same direction as the front wheels, instead of the opposite, then u r in big trouble if the front doesnt turn in. in an understeer situation, that would have the rear wheels turning u straight off the road!!
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4753813
i would have to agree, i had a loaner R33 sedan with hicas, and for a big heavy car, this thing handled quite well and could be easily thrown around. i have no idea why people complain about hicas so much. i think they hear that one person doesnt like it and calls it useless, then it MUST be. if it WAS useless, car manufacturers wouldnt be equipping cars with it.......
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4754142
I think the biggest complaints about HICAS come from anyone who has a dedicated track/drift car, or frequents a track for racing or drifting. And because every second person thinks of themselves as a race car driver or drifter they remove it based on what the real race driver and drifters have said.
Personally I liked the HICAS on my old 32 but can vouch for the fact that once the tail end is out there, it's too easy to over correct because the HICAS system is also assisting the turn.
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4754451
You have to love the original HICAS implementation in the R31's - it had a couple of rams and flexed the entire K-frame on it's bushes!
4WS seems to have dropped off the radar these days, possibly due to it's mechanical complexity vs. what you can to with ESP and it's broader safety benefits.
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4754683
open your eyes before your mouth please
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4755401
i really enjoy hicas . and really notice when it comes on . eg same piece of road at different speeds . also mint for turning on hicas test and your car sits there and every 2 seconds the rear wheels move full lock (1 degree ish) one way and then other way then back to normal as fast as they can . and every one says wtf is your car doing ? "its break dancing "
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4755416
Has anyone ever had HICAS work in a straight line? That sort of issue, giving the car a 'flick'? Possibly due to the wheel not being on straight...?
only when the speedo cable snapped when i was on my way home from work, hicas started playing up along with the usual heavy steering. i was crab walking up a straight road, very strange feeling.
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4755455
That's exactly what I had but without the heavy steering. :) Definite crab walk. Happens at higher speeds like 80km/h and you need to steer into it and if slow down quick a flick out of it. I recently had work done on the suspension but the steering wheel is not that straight after the alignment and wondered if that had anything to do with it...? Speedo cable is all good.
https://www.sau.com.au/forums/topic/282242-hicas/#findComment-4755483
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
