19 Inch Wheels With Great Tires
From memory it's a ROM thing. Each option that is added will change the ROM they use for the ECU. Some times it's just enabling it via a tool.
Thanks for the response Guys , so far the mechanic has topped up the coolant and I haven't noticed and further leaks , I'm going to see if there local workshop who might have a bit more expertise on the imports. if the pump needs replacing I'll give you guys a heads up.
What was the usage like with this car? Was it a track car? Did it see much time bouncing on the rev limiter? -
We won't be able to tell anything from those photos. Most of them are unnecessary for making decisions about what's good or bad anyway. The ones that matter are the of the crank. And we can't tell what state it is in from those. Take it to an engine builder and ask for it to be inspected and measured. It can probably be brought back just with some machining and undersized bearings. Worst case, you buy a new billet crank. Everything else is fine. New pump, new turbos, new pistons, rings, bearings, etc etc etc etc.
No. The rear hat is different, so you have to swap that. At least that is doable. The splines are not the same. Stubs from one will not go in the other.
