man that sucks :P
im no help, i have no idea what it could be.
i guess i'll see how i go when i take my car in, i'll try fulcrum first.
I'll be having a hicas lockbar put on aswell, so i'll let you know how that goes.
Is your steering fairly neutral? i found while driving at about 100kms i can swing the wheel left and right a few centimeters with little to no feedback. and once i get to 110kms it starts getting a bit shakey
Maybe the car has hit a curb at some point and something got bent?
i have had every car ive owned do this, its normal (to a certain extent ofcourse)
dont quote me on this but i have heard time and time again it is purposely meant to drive left if u fall asleep behind the wheel so that you dont hit oncoming traffic on your right
kind of makes sense to me but knowing every car that i've owned slightly pulls to the left if i let go of the steering wheel hints to me that its a deliberate thing by design even tho all of them have been wheel aligned atleast once whilst in my possesion and all specs were what they are meant to be
i have been told that a adjustable caster rod setup can override this, thats as far as my knowledge goes with this matter
gl
funny you mention that, just noticed my driver side rear is slightly higher than the other side. i'll need to get that adjusted too. haha
Steering is perfect, no slack whatsoever, no vibration at any speed everything is 100% even just checked the ride height and all 4 are 380mm!
Hopefully someone can help?????
Mate I honestly feel your pain...... Until yesterday! Got a new set of tyres fitted and it drives dead straight! Check the condition of your tyres!! Mine had plenty of meat on them but the rubber was just really old! Side walls and everything were saggingy!
Having said that rather than spending 400 now on tyres borrow a mates set of tyres! And see if that helps, cause u don't wanna spend another 400 for nothing- ensure your tyres are correctly balanced!
new tyres helped me alot also. did the swap with the wheels from my old 33 to check first.
another thing i noticed last night... i have volk gtcs and the centrebore on the rim is larger than the hub.
I put some hubcentric rings over the hub to fit the wheel better. now my shakey/dodgey steering at 100km/h+ has gone away.
Still pulls a little to the left, but it doesnt seem quite as bad now.
What wheels are you running? another thing for you to look at maybe?
I'm starting to think it's the tyres too.
I'm running stock wheels with 225/45/17 tyres which are only 6months (11,000k's) old but they are crappy Achilles which I'm guessing were the cheapest the complier could find!
I just put around 275k's on the car this weekend and overall it is better. When I travel in the right hand lane on the M1 it will actually drift right but nowhere near as much as a left cambered road. Also the overall steering feel is alot more responsive than before. A bit unsetteling to begin with as the car was very responsive anyway but I'm used to it now.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
