I saw a number of products at Repco that says it removes this and that, not sure if I can remember seeing one specifically for Tree Sap though.
Maybe try soaking it first for a while, get an old Rag, wet it with warm water (maybe the warmer the better) and just leave it on the sap and let it soak for a while, then try scrubbing it off?
Hope you can get rid of it, good luck.
Razor blade on glass is quite easy actually.
That is how carwashes remove stickers, etc from the windows.
It is not that hard, or subsequently take it to the car wash and get them to do it for you.
Razor blade followed by clay bar :)
Don't worry, it won't scratch your glass. Try and get those long thin razor blades that can sort of bend to the glass' shape. Once you've done that, simply follow up with clay bar to get it back to normal.
I've heard eucalyptus oil works too, but i haven't tried/seen it done.
Tried most except for the eucaliptus oil to no avail...got my side windows tinted this w/e and the guy doing them let me know that it wasn't tree sap but acid rain marks.
He recommended a clay bar and window cleaner for moisture....tried it and it kinda work, reduced some of the spots but not all of them. I guess i need to do it a few times to get a better result
For tree sap, i can tell you that hot soapy water works. I got it off my paint easily. Use almost-boiling hot water, and have the car sitting in the sun for a while before pouring it over the affected areas.
Then wipe it off with a soft cloth. You wont believe how easily it comes off. I tried metho and a host of other scary things. They didnt work.
