TS Astra I think I got mine from running in a front wheel drive rally car. Despite the short sighted people around... they have been in use in the Off Road Racing for many years for all the positive reasons mentioned.
The standard Holden Astra one is as robust as any on the market and given most people don't know what they are you can pick one up from a wrecker for as little as $250.
For the people who have not seen one they are power assist and have better feel than any Nissan (or any other) mechanical pump. They ramp up the pressure when needed and run in an idle state when nothing is happening. Mine is wired to a switch on the dash so I can turn it off when on the dyno.
If someone gets one and needs a hand with the wiring I can dig up something as it is as not straight forward with more than 1 power wire and from memory the wire colours are odd.
  • 8 months later...
Josh's 180SX has an astra pump fitted as there was no room to put an engine driven pump onto the VH45DE.
It's been wired up to run constantly, and works very well, but I think it would be better if it did have a controller (lucky the alternator is a 110Amp unit on the v8).
  • 2 months later...
well the astra pump works ok.
i installed one in the uas zed. its quite heavy. and on full lock it draws 75AMPS, at idle with no steering its about 25A.
these pumps were designed to be mounted very near the rack. one thing ive noticed is a slight lag in assistance as its mounted in the boot and has 4 odd meters of hose to the rack. (any hydraulic gurus chime in) we used -4 teflon. mayby -6 with a restrictor would of been better but once your going it feels fine.
they run at full speed 100% of the time. the electronics inside keep the pump at a constant rpm and feed in current to compensate for the pressure.
try using a simple accumulator... should be available from any available hyd supply joint. It just picks up the initial demand.
J.
HAHA good idea, gonna steal that idea :P
  • 5 years later...
Have plans (as in interested, talked a bit, done nothing towards acquiring the bits yet) for an R chassis and an S chassis, with the Astra pump setup and a steering quickener.
Main identifiable issue is lag on the assistance - unknown just how much flow capacity is available from the electric pump vs even a standard engine driven pump.  Neither is really spec'd for motorsport application.
They fit under the driver's side battery tray nicely. 1m run back to the rack, botlt them to factory GTR bov points.
Have a dumb unit, do wonder about getting a CAN one and if you could control it better than the internal logic on the dumb one.
Car hasn't really been run with it yet so we'll see how it goes
I would be really interested if anyone ever attempted to adapt a modern servo electric system to a Skyline, e.g. one of these Bosch units which are found in many modern cars:
http://www.bosch-automotive-steering.com/en/products/car-steering-systems/electric-power-steering-servolectric.html
I like the simplicity of these systems. I would imagine the control/electronics side of things might be the challenge given how different the steering feels on many similar models these days (e.g. different Porsche 911 variants), simply due to software changes.
  • 4 weeks later...
Hi, my stock belt driven P/S pump got a ripped hose under driving, the pump failed quickly as a result of that.
So, since it was hard and expensive to get a new pump here in Norway, I found a electric P/S pump from Mercedes A-class, wich got a reservoir in it, and that makes it easy to place around. Only require + and - power the way i installed it, so Hook it up with a relay and a switch, or on IGN. I found that this works very well for my daily driving, but I havent tried on track yet.
  • Like 3
Acrula, which pump do you think is heavier the nissan one or the A-class? what car do you have? any pictures of where you mounted it?
I've weighed an rb26 pump and I think it was 2kgs, just the pump no belt, bracket or lines but I will double check.
I'm thinking of sneaking one in under the starter motor, even if it weight is close to the same, having it lower and further back would be nice.
Think I might head down to a wrecker and ask them if I can look at and weigh every type of electric pump they have.
Edited by aleks
Pretty sure that and all others would be to tall to fit there.
Astra one is not light. Would be more than pump+bracket+belt+lines+res
A class one looks a tad lighter
Is there any difference in steering feel now that you are using the electric pump?
I agree Justin that a class one looks too tall, but I meant to try and fit another, smaller powersteering pump under there.
Going to try and get a hold of a toyota mr-s power steering pump. The astra pumps look abit too big/heavy for my liking plus I dont want to dirty my car with an opel part.
I just weighed a gtr pump with the pulley, belt, bracket and bolts and they come in at 4kgs.  Will weigh the lines and resevior and lines when I pull it off.
Sorry for late reply. Not on this forum that often. I dont feel any difference at all under normal spirited street driving, but I have not tried it at the track yet.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
