After the succes of the past couple I have run, I have decided to run another :/
As ORAN PARK is closing in DECEMBER 2009, it is getting extremely hard to find available days or dates to run these type of events.
So listed below is what it is all about :laugh:
EVENT: ORAN PARK SOUTH TRACKDAY
DATE: TUESDAY 20TH OCTOBER
BRIEFING: 8.45AM
TIMING: No
DRIVER TRAINERS: JOHN BOSTON, DEAN CANTO and another yet to be determined Driver Trainer.
LUNCH: Yes this will be provided, along with drinks.
COST: $220 per driver
I am looking at keeping the numbers fairly low, and probably going to have 2 groups.
Alot of you probably have not had the chance to have Dean Canto beside you. I have known Dean for a while, as I signed off on him getting his CAMS licence a few years ago. Dean will be doing Bathurst a week or so before this event in the V8 supercars, so I am sure that his eye will be in.
If you are a first timer, or even a seasoned campaigner this is a great day out. Oran is still regarded as one of the best circuits to set up a car on :P
Edited by Bozman1
  • Replies 41
Yep, the 180 will be there for sure :down:
It will not be 100% finished, but at least it will be out having a run.
It will caged and looking shit hot :P
I wanna chase the little rocket around oran, see if Canto can keep up too :P
I wanna chase the little rocket around oran, see if Canto can keep up too ;)
Yes, thanks to you Brad it is going to have the best cage I think I have seen in a 180 :P
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
