After the succes of the past couple I have run, I have decided to run another :/
As ORAN PARK is closing in DECEMBER 2009, it is getting extremely hard to find available days or dates to run these type of events.
So listed below is what it is all about :laugh:
EVENT: ORAN PARK SOUTH TRACKDAY
DATE: TUESDAY 20TH OCTOBER
BRIEFING: 8.45AM
TIMING: No
DRIVER TRAINERS: JOHN BOSTON, DEAN CANTO and another yet to be determined Driver Trainer.
LUNCH: Yes this will be provided, along with drinks.
COST: $220 per driver
I am looking at keeping the numbers fairly low, and probably going to have 2 groups.
Alot of you probably have not had the chance to have Dean Canto beside you. I have known Dean for a while, as I signed off on him getting his CAMS licence a few years ago. Dean will be doing Bathurst a week or so before this event in the V8 supercars, so I am sure that his eye will be in.
If you are a first timer, or even a seasoned campaigner this is a great day out. Oran is still regarded as one of the best circuits to set up a car on :P
Edited by Bozman1
  • Replies 41
Yep, the 180 will be there for sure :down:
It will not be 100% finished, but at least it will be out having a run.
It will caged and looking shit hot :P
I wanna chase the little rocket around oran, see if Canto can keep up too :P
I wanna chase the little rocket around oran, see if Canto can keep up too ;)
Yes, thanks to you Brad it is going to have the best cage I think I have seen in a 180 :P
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
    • I remember reading that there’s a power steering pump from a modern car—possibly a Mazda—that bolts directly onto an RB engine and lines up perfectly, making it a great option for HICAS removal. Unfortunately, I’ve forgotten which model it came from. Does anyone know what vehicle this pump is from? Any help would be appreciated.
