Hey all,
I searched but had no luck as I cant get it to work.
Anyway I have a 4 door r33. It has a powerfc with hand controller, Front mount, Greddy style inlet manifold, stock turbo running 11psi, full exhaust blah blah blah. A while ago my engine fan decided to explode through my radiator :/ So I went out and got myself an alloy radiator with a thermo on a temperature switch.
I am after a temperature at which I should set the thermo to kick in and start cooling. Half way on the stock temp gauge is anywhere from 75 up to 90 degrees so I can't set it by lookng at that.
Any help would be appreciated...
https://www.sau.com.au/forums/topic/282367-rb25det-running-temperature/
You can set the thermo to come on as high as 90, even 95.
The idea of a thermo is to only react to extreme coolant temperatures. Ordinarily, as the car moves along there is sufficient airflow through the radiator core to control the coolant temp. Even after idling for several minutes - like in stop-start traffic - when you get moving again, the air movement will cool the coolant back to the thermostatted temp.
i dont have a fan
havent had one since the FMIC went on
no issues with overheating etc
the radiator was replaced with a better core though (original was leaking)
my temps are normally too low, under 80 is common
80deg is ideal water temp, with default settings, the PFC (and stock ecu) will retard timing and richen up until it hits 80deg
its a minor correct, but its still a correction. i could never get my car to 80deg so i changed the water temp to be 0 0 and 50deg
so from 50deg onwards theres no correct. its covered in the PFC FAQ in my sig
i dont have a fan
Do you run glycol in your coolant/water? Adding/increasing the gylcol concentration would make the system less efficient and should nudge up the temps. Also means you don't have to worry about boil until even higher temps.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
