Hey all,
I searched but had no luck as I cant get it to work.
Anyway I have a 4 door r33. It has a powerfc with hand controller, Front mount, Greddy style inlet manifold, stock turbo running 11psi, full exhaust blah blah blah. A while ago my engine fan decided to explode through my radiator :/ So I went out and got myself an alloy radiator with a thermo on a temperature switch.
I am after a temperature at which I should set the thermo to kick in and start cooling. Half way on the stock temp gauge is anywhere from 75 up to 90 degrees so I can't set it by lookng at that.
Any help would be appreciated...
https://www.sau.com.au/forums/topic/282367-rb25det-running-temperature/
You can set the thermo to come on as high as 90, even 95.
The idea of a thermo is to only react to extreme coolant temperatures. Ordinarily, as the car moves along there is sufficient airflow through the radiator core to control the coolant temp. Even after idling for several minutes - like in stop-start traffic - when you get moving again, the air movement will cool the coolant back to the thermostatted temp.
i dont have a fan
havent had one since the FMIC went on
no issues with overheating etc
the radiator was replaced with a better core though (original was leaking)
my temps are normally too low, under 80 is common
80deg is ideal water temp, with default settings, the PFC (and stock ecu) will retard timing and richen up until it hits 80deg
its a minor correct, but its still a correction. i could never get my car to 80deg so i changed the water temp to be 0 0 and 50deg
so from 50deg onwards theres no correct. its covered in the PFC FAQ in my sig
i dont have a fan
Do you run glycol in your coolant/water? Adding/increasing the gylcol concentration would make the system less efficient and should nudge up the temps. Also means you don't have to worry about boil until even higher temps.
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
    • People don't always want builds that are overly expensive, or have engineering/registration/insurance issues and head aches that come with them Whilst big dollar builds, and complicated stuff is interesting to watch, there is only a tiny % of people who would actually use this information, or have the spare finances to drop on said builds, whereas the buy a cheap(ish) cool car, and make it better, with a average budget, that the average Joe or Jane could achieve will always be a winner in my opinion
    • Bit of a thread revival, you mentioned wanting a bit more top end before, do you regret not going with the 1.01?
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
