Hello there,
I came across this video clip showing a blown turbo and where the exhaust turbine ends up.
Later the turbo gets rebuild ..
I found this quite interesting so here we go: (windows media player required)
R34 Blown Turbo
Edited by Torques
dunno why but alarm bells are reinging due to this whole post/link ..even tho it looks like a video link
Hmm?
What do you mean?
It is a link to a video file! :banana:
I set this up myself ... no virus or anything funny...
Trust me on this ... I'm one of the good guys (registered in 2006) ;)
Cheers,
Andrew
Edited by Torques
hahaha call me paranoid but I still find this whole thread strange and sus .. the video link gives me a prompt and trying to right click the file and download isnt allowed, some sort of scripting used to give a fake error..Dodg-eeeee.
Mate,
You a very much in error :mad:
There is no scripting whatsoever ..
And you can right click anywhere you want.
I could not link to a media streaming server in this board directly, so I had to link to a HTML-Page (my page just containing one link (PLAY ME)) that in turn links to the video file.
The video file is streamed via a windows media server (my own) to make it convenient for you people to watch it.
There is no, and I repeat no dodgy script or anything.
And there is no fake error ... and no file to download!
It's streaming!
Have you ever right clicked on anything in YouTube???
Get educated on the issue :D
Geez, you are paranoid for sure :happy:
Edited by Torques
hahah yeah I am sorry .. yeah i watched the vid, interesting :happy: it must be cause its a streaming vid (cant dl it directly) that's causing the fuss on this comp..
No damage taken ...
And I agree with you that there are lots of dodgy things out there and sometimes it's hard to tell.
I'm glad you could watch the video alright and your computer took no harm :mad:
Many cheers from London.
Andrew
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
