lolz whats goon? is it cask wine?
Yep.
So long as you have the correct decals and of course the turbo muffler..... nuffin' is going to touch ya!
It's important to list all the best performance parts in the world on your front guard, especially if you don't have them. The decal is as good as the actual part down the quarter.
Edited by scathing
  • Replies 120
then you will get Jap-Spec Godzilla! :D atomic breath FTW!
US-Spec Godzilla sucks that thing can't do sh*t except eat fish & run and hide at the 1st sight of US attack choppers...
so what would i feed a mutant dragon? would i need to make mutant cows?
Any nuclear waste left overs is good enough I say... no need to go into the effort of breeding mutant cows.
i just had a thought. if i get together with a few other people with dragons we could start hijacking trucks carrying uranium by stealing their trailers while they are driving along. i saw something similar on a movie. i think it was called "the trucks that kept getting hijacked"
what about feeding it straight uranium or enriched uranium (bit harder to get and more expensive)?
If you can get the power up to 1.21gigawatts (should be easy if you stick a big cam and roller rockers in it, along with a Holley tunnel ram) then you can drive it into the future and get a Mr Fusion conversion.
I thought it was called "Rapid and Angry"?
well excuuuuuuuuuuuuuuuuuse me LOL
? Watch the last 3 seconds...
& also 1.21 jiga watts is piss weak by today's standards. You gonna get out run by every man & his dog who owns a bog standard thirst - 8.
What you need is the
turbo. Edited by Mayuri Krab
Wow, hasn't been closed so I thought I'd add.
By your cousins reasoning, even having 4 valves per cylinder is fake.
It's all about efficiency. Making an engine more efficient is the key. They used to think having more cylinders and bigger capacity was the way to do it. Turbochargers only make up for the lack of cylinders and make an engine more efficient. Honda perfected engine efficiency in their S2000 engine which was stated earlier.
Tell your cousin that when he can stop his knuckles from dragging on the ground for a second, he will be halfway to being equiped to make an arguement.
But remember....never argue with an idiot, he will drag you down to his level and beat you with experience.
I would only drive a v8 bored out to 10 cylinders, and twin-big-single turbo charged.
Hahahahahaha! Are you gonna smelt down the V8 to construct this V10?
I'm gonna bore my Skyline out to a Ferrari.
I remember that Zelda cartoon! It was part of the Mario Brothers cartoon wasn't it?
<<<<<<<HAS DRANK ALL THE BEER AND HIT THE VODKA
I've had this crazy idea that i could melt 2 rb26 engines together to make a 5.2L V12 quad cam 48 valved quad turbo monster that runs on methane produced by the mutant cows, should eat Veyrons for breakfast anyone want to help and maybe supply me some spare engines... :P
Edited by doozooby
I still cant get over "fake power" lol.
Nah steam power is where it's at. A Commodore SS Ute can haul it's own 'coal bunker' about in the back. That is REAL power, non of this soft as internal combustion engine cr@p. :P
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
