  • Replies 43
Short answer: BAD...
Don't do it!!
BOV is there for a reason. To allow the pressurised air to NOT hit back onto the turbo compressor wheel. Over time it may cause damage to the fins.
Why on earth would you want the "flutter sound" anyway?? I hope it’s not to sound "cool" :banana:
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4756251
Lol, this topic again?
50% of the world will say its bad, the other 50% will say it isnt. Personally i think it sounds awesome, but at the same time i fully agree with Adam, i dont see how it cant be bad for the turbo. Its compressor surge, spinning the turbine backwards, it can not be good. If you didnt need a BOV, why would anyone have them?
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4756421
  NA_Goodness said:
Or if you aren't sure, just run the standard BOV. My car has the stock one and a pod, and everyone loves the pod flutter (more of a whoosh).
+1
I'm loving my whoosh sound from my pod :down:
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4757123
The sound of flutter/dose is awesome. Love it.
It will kill a ceramic turbo like stock R32, R33, R34, S13-S15 turbo's. Won't kill steel turbo's like single VG30 turbo's or RB30ET turbo's.
Flutter at 10psi is ok, but if you are running 14+ psi through a RB20/25 turbo it will kill the turbo
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4757562
+5MILLION
Dosing/flutter is THE BEST SOUND !!!
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4758372
THANK YOU!
farken hell...
I blocked off my BOV ages ago as it was leaking and I kept it like that as it sounds better then an atmo bov and is still legal...
Boost (on standard turbo (presumadely)) is now at 1 bar and it's been like that for a while... turbo still isn't dead.
Either way, overheating and general miscare of the turbo will destroy, fluttering can be a part of this but not a main part...
https://www.sau.com.au/forums/topic/282464-flutterdumpdose/#findComment-4758925
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
