  • Replies 43
Is it just me or do 50% of the people on this site really only want a turbo vehicle for the noise? I like my turbo for the acceleration and find the noises annoying.
Yeah that's true for me <puts hand up> :banana:
The acceleration is a nice added bonus, but I have never boosted my car to its 2nd stage boost (7psi) as I have never revved it past 4,500rpm in normal day to day, point A to B driving. & that's all my car is used for, as a daily drive around Corolla.
Yeah it is... my roommate bought one for his TT supra... I had to drive it to the mechanics last weekend cause he was working... fuvking embarrasing as shit!
What a stupid noise to come out of a car...
You did? from what I remember your 34 had that "whoosh" sound, like the factory BOV with pod ?? not that you revved very hard when I drove along side you.
yeah when you heard it, was when I had the stock bov back on, had a HKS a month or 2 before and the sound got too annoying so ended up smashing the stock back on...
some bov's like the blitz have a little allen key screw which u can tighten and un tighten... tightening this screw will make the spring harder and will not allow the bov to open fully under boost. This will also give you flutter.
Untightening the screw will open it up and give you the normal sound.
Edited by br3ndan
Agreed, alot of tosser's just love the sound of it, but "Haaaa Chew Chew Chew" is much better than that quick high pitched squeak those WRXs and EVO's do, f**k man, hearing that shit makes me homocidal.
YES could not agree more i hate the squeaks and whistle sounding ones, worst when you see them at a motorplex trying to drop a skid shit sounds horrid.
i facepalm so hard my nose hurts
I'd rather pull my exhaust apart to find my turbo blades than have that squeak shit.
This in a lower pitch would sound sick. Like, the same pitch as spooling up on a stock RB 32 turbo
(the sound the Supra makes after the burnout, not during the race)
All this talk of flutter pipe dump dosage is making me dizzy.
Edited by Nic_A31
LOL Krab, are you serious? never taken it over 4500rpm?!
Pretty much, usually I make sure the gear box changes at ~3 to 3.5k rpm. :D
i have a standard BOV with pod filter ad it sounds great. it flutters nice but it can also be quiet when i want :)
and its not illegal :(
+1, also if I drive super granny then theres no sound at all.
i think the dose a stock turbo sounds a bit wierd but still u can change that with the different front pipes u use. i have a rb25 with a top mount gt35/40 and that sounds good dosing and so far i don think its done any damage but i think a bov is healthier for your car but i don see ne skyline or vl turbo being treaded nicely to prolong turbo life neways so just do it =) i dare say u might not like the sound or the engine will run rough with a afm neways so u may have no choice but to put it back standard . doesn hurt to try if ur bored though
just installed my blitz bov (with the little air filter thingy)
sounds awesome, better than the high pitch ssq sound hehe
and better than flutter but yeh, with this bov i can make it so tight it won't open + cause flutter or just let it go PTSHH :ninja: sounds 1337
  • 7 months later...
agreed it is 50/50 whoever u talk to so personal prefrence is the choice in the end.I took off a gfb ppssshhht bov on my 96 180 for flutter and at 1 bar evryday 4 4 years it didnt kill the turbo...
I have a question to any gurus out there if can help,
I just bought a 32 4dr and it is a very good tuned street car and runs a upgraded turbo and tuned power fc with hand controller.My question is will blocking up the standard bov (previous owner kept it not aftermarket 1) "throw out" somehow or interfere with the power fc or not..
Cheers :woot:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
