Thanks to Willall Racing the JPC GTR has just had a few more upgrades.
We have changed out the standard Transmission Fluid for the Willall Racing fluid. Also installed the Willall Racing High Volume Sump. Now takes close on 8 litres of oil. My past experience with GTR's suggests that this will be one of the best improvements that I will make to the car.
I have attached a pic of the Cobb accessport that we will start playing with. Hopefully we will use it to lean out the safe tune that is in the Mines Type X ECU in the car now.
Loving the car
https://www.sau.com.au/forums/topic/282466-jpc-gtr-gets-willall-treatment/
Spot on Danny, nothing like some extra sump capacity....now you just need some of these -
What do they do?
- Roller Bearing Core for strong response (replace factory plain bearing)
- Larger compressor wheel (+100awhp better from test data)
- Larger turbine wheel for reduced back pressure
- Properly measured and machined factory turbine and compressor covers
- Use high quality factory lines
- Completely stealth apperance from the outside
