As an engineer who sets up various control loops in industry I will have crack. A controller typically has three values of interest:
Setpoint (SP) - The amount of boost you want
Control Value (CV) - The output to the variable bleed valve, or pulsing of on/off valve or pushing/pulling the wastegate itself.
Process Value (PV) - The amount of boost you are getting.
To manually set one up you would typically make a step change to the CV (eg. valve from 0% to 50% open) and measure the response to the PV (how long it takes to reach the final boost value, and rate of change). With these measurements you set controller such that it gets the value you want as soon as possible, with little over shoot, and then hold where you want it.
A "learning" controller does this for you. While learning it changes whatever it varies to effect boost level and measures what effect it has on boost with your setup (ie. your turbo, your exhaust, ambient temp etc.).
It's not hype it's necessity. If it doesn't learn you would either have slow spool up or overshoot.
  • 4 weeks later...
with the GReddy Profec A, its learning mode is used to learn the features of the actuator type, external wastegates, and the stability of the boost curve. There are two learning phases:
1. Learns the stock base boost level
2. Learns the basic boost curve and the difference between the pressure in the wastegate and the pressure in the intake manifold.
You need to run the learning mode again after any changes are made to the characteristics of the wastegate spring or the power output of the engine.
Not sure about the apexi boost control kit for the pfc, but would assume it is similar.
for example, after installing my pfc, Z32 afm's and cam gears, I had trouble with boost spiking and then dropping off at high rpm. After running the learning mode it now once again holds my desired boost level spot on through the entire rev range.
