As an engineer who sets up various control loops in industry I will have crack. A controller typically has three values of interest:
Setpoint (SP) - The amount of boost you want
Control Value (CV) - The output to the variable bleed valve, or pulsing of on/off valve or pushing/pulling the wastegate itself.
Process Value (PV) - The amount of boost you are getting.
To manually set one up you would typically make a step change to the CV (eg. valve from 0% to 50% open) and measure the response to the PV (how long it takes to reach the final boost value, and rate of change). With these measurements you set controller such that it gets the value you want as soon as possible, with little over shoot, and then hold where you want it.
A "learning" controller does this for you. While learning it changes whatever it varies to effect boost level and measures what effect it has on boost with your setup (ie. your turbo, your exhaust, ambient temp etc.).
It's not hype it's necessity. If it doesn't learn you would either have slow spool up or overshoot.
  • 4 weeks later...
with the GReddy Profec A, its learning mode is used to learn the features of the actuator type, external wastegates, and the stability of the boost curve. There are two learning phases:
1. Learns the stock base boost level
2. Learns the basic boost curve and the difference between the pressure in the wastegate and the pressure in the intake manifold.
You need to run the learning mode again after any changes are made to the characteristics of the wastegate spring or the power output of the engine.
Not sure about the apexi boost control kit for the pfc, but would assume it is similar.
for example, after installing my pfc, Z32 afm's and cam gears, I had trouble with boost spiking and then dropping off at high rpm. After running the learning mode it now once again holds my desired boost level spot on through the entire rev range.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
