...I would be able to supply a Deutsch plug kit that comes with a host of different sized plugs (pine wise) and the special crimp tool.....
sounds excellent - can you post up indicative price and kit contents? got a link for ther deutsch catalogue?
I went the 1/2 cheap and lazy option. S13 but the process is still much the same.
I utilized the fuse/relay/fusable link box from the engine bay and mounted it to the tunnel under the dash. This holds all my relays and links and from memory the head light fuses are still in it. As there are a bunch of circuits no longer used i popped out 2 of the fuse holder sections and you can clip in an extra 2 relays.
I retained the factory switchgear and wiring for them as well as the wiring for the wiper motor and shortened them all up to the new location. Stripped the afm wiring out of the engine loom and split that section with only the afm running to the front of the car and the rest of the loom now running inside the cabin to the fuesbox.
Battery is mounted to the floor behind where the passenger seat would be, +ve runs through a cut off switch to a distribution block which on one side goes to one of the cheapy narve fuse holders (i'm having second thoughts after reading this thread).
head and tail lights are done with 7 core trailer wire, 1 extra heavier wire running back for the fuel pump.
Alternator and starter were done as an entirely new section of loom and run through the existing driver side grommet in the fire wall.
I also rewired the power windows. They are now run with 2 2 way self centering switches and 4 5 pin relays so no issues with the factory box breaking or finding where/how to mount the factory switches neatly with no door trims.
Edited by badhairdave
ill see what i can do. im starting a haltech full engine loom rewire saturday so ill try and take some pics of how things are done.
you dont need relays on the electric windows. good quality switches will do the job just fine. its more so in the wire. if you are going any distance with the wires than you should use a minimum of 5mm wire.
Great topic guys!
I actually work for the company that distributes NARVA and PROJECTA brands. Our catalogue's have around 4,000 SKU's but we carry about 14,000 Part Numbers. Meaning theres lots of stuff thats not obvious to consumers. We can obtain almost anything automotive electrical from our many suppliers OS. If your after anything in particular, let me know and i'll try and source it.
We have also just done a deal to distribute the Deutsch brand of connectors and wiring systems. These will be available soon from all the usual retailers such as Repco, Bursons etc.
If anyone needs help/advise with this sort of thing. Just ask.
Warren
Agreed! The Deutsch connectors are the best automotive connectors I have used. We make plenty of OEM wiring harnesses for trucks and trailers and they are easiest to use.
I also know that motec use them for their wiring systems. They are tested for ingress to IP67 which means they can be submersed in water up to 1 M. Enough for most GTR's!
deutch is the way to go not cheap but good $170 for the motec sdl dash plug
the ultimate is a PDM power distribution module not cheap either but no fuses no relays just wired outputs programed to what current cutout needed and logged
Can you post up some pics of the PDM. I'm curious.
the deutsch connectors are the plan for every plug i can get suitable ones for, i found the hd30 series are the ones for the firewall bulkhead for the main loom in the engine bay. I bet they arn't cheap, any chance of a price on them StockGTR, DJRIFT?
http://www.deutschipd.com/hd30_hdp20_techman.pdf
I saw an article on the motec PDM recently, I will try and find and post it.
Essentially it is a fully programmable power output....so 1 big supply wire in, many many individual circuits out, and a couple of trigger wires in (+motc ecu feed). You then program each output to allow up to a certain ampage (programable fuse) and what will trigger it (any of the input wires, any ecu parameter, any threshold values). No further relays, fuses required, and only need switches if you can't switch based on some existing parameter. Brilliant new way to look at things but the PDM is worth more than the rest of my car :blush:
As always my interest is in the cheapest reliable option so no PDM for me.
Yeah, i considered it but was unsure of the current draw of the motors so went the beefier option rather than have to re do the whole lot later if stuff melted on me.
Essentially it is a fully programmable power output....so 1 big supply wire in, many many individual circuits out, and a couple of trigger wires in (+motc ecu feed). You then program each output to allow up to a certain ampage (programable fuse) and what will trigger it (any of the input wires, any ecu parameter, any threshold values). No further relays, fuses required, and only need switches if you can't switch based on some existing parameter. Brilliant new way to look at things but the PDM is worth more than the rest of my car :D
and here it is http://www.autospeed.com.au/cms/A_111402/article.html
  • 1 year later...
  • 1 year later...
Digging up an old thread as this stuff really interests me.
Has anyone had any dealings witht he MoTec system Duncan mentioned above?
Been looking at the recent release of Racepak's smartwire, very similar setup witht he new software being released soon.
Very happy with their IQ3, so I'm keen to look at their other products.
Link: http://racepak.com/Components/Smartwire.php
I'm rebuilding two cars at the moment using PDM15's so far i have found them to be very good, once you get everything that you need from Motec to run them, as they do not come with any of the plugs etc.
  • 9 months later...
Dale,
Sorry, I didn't get a notification of your reply, the PDM15 is around $1800 and that does to job on most cars, I have a M48 in the car but it doesn't directly communicate with the PDM as you need CAN for that, I use a few of the outputs from the ECU to drive the PDM (Fuel Pump, Intercooler spray) and use an AiM Sportssystem EVO4 data logger and MXL Dash.
Thanks for the reply mate. I'm running a Wolf V500 at the moment with the Racepak dash, and I'm wishing I went down the MoTec ECU, PDM and Dash route now. Oh well maybe on the next car.....
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
