Hi all, I recently picked up a pretty worked R33 s2. Always been into Valiants/Chargers so this is a little different. :down:
The car has been great but in the last 250km's or so it's developed a problem that seems to occur the more I drive it. At random times when driving, whether running low or high boost, whether the car has been running 5 minutes or an hour, the throttle simply dies. It feels like I've taken my foot off the accelerator pedal; it just looses throttle. Then 1~3 seconds later it kicks back in. Then dies again. etc. It mainly happens driving around town (low RPM), but has occurred on the highway too. Additionally a couple of times when I've started the car up it hasn't idled as high as it usually does and even after warming up for a few minutes it conks out when reversing out. I don't thrash the car (much...) and have only had it happen when doing normal driving, IIRC.
I checked the Power FC hand controller and when this occurs the InjDuty momentarily hits 0% (or otherwise decreases significantly) and IgnTiming drops significantly too (i.e. ~50% down?). The other stats on the 8-way readout appear normal. The throttle 'dropouts' only occur for a split second or couple of seconds then it's fine, then a couple/few seconds later happens again. Usually the problem disappears a minute or two later but it happened yesterday intermittently for about 20 minutes and today seems to be hanging around and showing it's head every 10 minutes for a minute. When the problem happens, there's sometimes (but not always?) a clicking at top of engine; unsure if related (only noticed that this morning once when I had the bonnet up, then it went away).
BTW car was recently tuned and runs very hard 95% of the time without ANY problems whatsoever, so I guess it can't be the tune. Knock is still very low (usually 1~10; hasn't changed since this problem started) and I'm strictly running BP Ultimate 98.
EFI/turbo's are new to me and I feel a little lost...what am I dealing with here?
Any help would be GREATLY appreciated.
heycharger
https://www.sau.com.au/forums/topic/282545-engine-cutting-out-randomly/
Very nicely explained, I'm having the same problem on my RB25DE NA... Got no idea what it is or how to test it? Some people say it could be a dodgey AFM but I have sprayed the sensor inside with carby cleaner as suggested, and resoldered all the joints tightly.
The best way of telling whether you have a problem is to plug the car into a laptop with diagnostic software (I bought some diagnostic software = "Nissan Data Scan" for my SR20DET for $40. You need a plug as well to plug into the OBDII plug on the ECU. which is under $100.
THEN you can find all the problems with the motor and see if all the sensors are ok! Easy!
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
