I've got a mate with a 2.4 turbo, injected, intercooled C210 and it boots along! I know very little about it though; not sure if it is an original JDM c210 2000GT-ES turbocharger or something bigger. The intercooler and computer are definitely aftermarket.
https://www.sau.com.au/forums/topic/282553-mr30/#findComment-4757582
What price would you put on a Mr30 82, 4 door L24 turbo with intercooler and 5 speed. In good condition. Does anyone own one and how do these perform.
there are a few really dodgey (like stock injectors/ecu/locked dissy and "she'll be right") L24 turbo setups out there, so it really comes down to what angine management is running it, and who put it together
a stock '82 MR30 will go for maximum $1000 to $1500 for a good one (registered), if you add a turbo setup to that (could be another $500 to $1000 depending what it is)
so $2500 is my estimate. any pics or more details on whats running it?
stock brakes and diff?
Ti spec or povo S pac ??
as for performance, with a stock ECU and injectors 110kW at the rears (by young josh from adelaide),
in a L20et stagefumer got 120kW on bigger injectors and a few extra goodies
I would say 130 to 150kW in a PROPER setup (aftermarket ECU, good piping/cooler/exhaust/dump)
https://www.sau.com.au/forums/topic/282553-mr30/#findComment-4757693
Hi,
There's one advertised for sale here http://forum.r31skylineclub.com/index.php?topic=133962.0
(If the link doesn't work, go to http://forum.r31skylineclub.com and look in the Trading Post > For Sale - Cars thread)
JH
https://www.sau.com.au/forums/topic/282553-mr30/#findComment-4759841
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
