Like all things, nothing is ever easy.
And so i need a few answers b4 i pimp the stag out, if you know-able types could help me with a few puzzles id love it!
A - Headlight angle adustment
B - "no idea"
C - "no idea" (sports mode?)
D - "no idea" (front demister?)
E - Passenger 3 way toggle seat heater
F - Driver 3 way toggle seat heater
G - "no idea" (diff lock for low traction like snow?)
Final set is actuly about globes, what type fits where? (im used to plain old H7/4)
H - "no idea" (D2R i think)
I - "no idea" (D2R possibly again)
J - "no idea" (crappy yellow fog lights)
And on the fog lights, i wont bother sending a pic. i have 3 settings for the fog lights Off, low icon, low icon + high icon. I couldnt tell a difference between both on settings. (and it doesnt have auto off, ill have to change that)
Thanks in advance guys!
https://www.sau.com.au/forums/topic/282557-vas-ist-das/
B heated strip along bottom of windscreen to unstick frozen wipers
C synchro button locks awd into 50/50 front rear for take off - gets overridden by computer once you get speed up.
D heated rear screen and on my car heats the side mirrors (may be disabled by compliance in Aus)
G snow button - locks out 1st so you take off in 2nd
English language versions of the handbook (but not the workshop manual) are available for about $40. You can have mine for $30 posted.
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4757399
EF heated front seats??
Yes, i have the leather interior with the heated seats. Kinda funny as i didnt explain it to the GF and just turned them on, funny look on her face when she finaly comprehended the heat under her bum.
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4757478
dont know aye . in saying i want one tho i dont really need it .i drove down a track that turned into loose dry sand so i stopped . . went and did whatever we were doing . upon reversing stalled it first go . second try gave it some more welly and i felt the back wheels slip for less time than i could count and it was straight to 5o% torque split and moving backwards aye . really worked better than i was gonna give it credit for . goes awesome on snow too aye .
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4759651
pop the headlight adjusting one out and make sure it's plugged in, mine was unplugged during compliance.
for the second position for your fog lights (with the 2 symbols), do you have 2 reversing lights or just one? if only one, the other light will have a red panel which is a rear fog light. this position turns that on
D.
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4760190
B - "no idea"
Thanks for all the replies, the answers are below!
B - Window wiper de-icer
C - 50/50 drivetrain split
D - Rear window de-icer/de-fogger
G - Snow mode, 1st gear lockout
And on the fog lights, there is front and rear fog lights.
Thanks for all the answers!
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4770427
It's to turn one of these on & off
I might as well put this here instead of starting a new thread.
Anyone know what this button does?
Sorry about the picture quality, my phone is shit and I dont have a proper camera
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4774868
Ah, thats interesting. My stag doesnt have one of those, i guess it must have been removed by a previous owner.
I've seen those sort of things on some other imports though, but never knew what they were for. Am I right in assuming it's an aerial of some sort? Or is that completely wrong? Sorry about the newby questions
https://www.sau.com.au/forums/topic/282557-vas-ist-das/#findComment-4775021
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
